- Thank you received: 2
95 kz1000p
- customkzft
14 Feb 2010 16:44 #348292
by customkzft
95 kz1000p was created by customkzft
I'll but to the chase. I got it running but only on two cylinders. There are two ok the left side that are not combusting. I changed the plugs and the carbs but still same issue. Not sure what theme deal is. Plugs are wet and when I pull them I see spark. I recently changed the head. Any ideas?
- roy-b-boy-b
- Thank you received: 103
14 Feb 2010 16:53 #348295
by roy-b-boy-b
Replied by roy-b-boy-b on topic 95 kz1000p
Do you have good compression? Roy
- customkzft
14 Feb 2010 17:57 #348304
by customkzft
Replied by customkzft on topic 95 kz1000p
Havent checked compression yet. I figured two pistons are running fine so why would the other two run bad? Not to mention on the same side
- TeK9iNe
- What did you do!?!
- Thank you received: 28
18 Feb 2010 09:58 - 19 Feb 2010 11:23 #349000
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 95 kz1000p
customkzft wrote:
You have to treat each cylinder as a seperate engine.
It has its own carburetion unit, and its own exhaust.
...and yes, one cylinder can be completely %^&@#$ right beside a perfect cylinder, it happens more often than one might think.
Pull all the plugs, and have the throttle wide open when performing compression check.
You say you've changed carbs? Do you mean a completely new rack installed? or just cleaned up the old ones?
Make sure carb float levels are correct.
The carbs likely need at least a good bench sync to get running, then a vacuum sync once bike is good and warm.
Make sure to have idle turned up good.
If plugs are soaking wet, they need more air/less fuel per gulp!
Good luck.
Keep askin the questions!
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 19 Feb 2010 11:23 by TeK9iNe.
- otakar
18 Feb 2010 14:24 #349036
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 95 kz1000p
If the non running cylinders are on one side and the plugs are WET than it sounds like a carburetor problem on those two cylinders. Especially if you have spark.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- pgboyd
23 Feb 2010 10:52 #349807
by pgboyd
Phil Boyd
Northern Virginia USA
1995 KZ1000P Police Bike
Replied by pgboyd on topic 95 kz1000p
I had the same problem with my 95 KZ1000P. Turns out that when I have the carb on full choke, 1 and 2 don't fire. If I take the choke to half choke (or off choke), 1 and 2 start firing. I took the carbs back off, soaked 1 and 2 carbs overnight in carb cleaner, and replaced the enricher rubber plunger pieces on all the carbs.
I haven't put it all back together yet to see if that took care of the problem, but you most likely have a carb issue.
Good luck.
Phil
Good luck.
Phil
Phil Boyd
