- Thank you received: 2
kz900 piston/ring options?
- Galactica
14 Feb 2010 09:31 #348220
by Galactica
77KZ1000
76 KZ900
kz900 piston/ring options? was created by Galactica
I know my 76kz900 A4 needs new piston rings. It runs OK and burns some oil. My plan is to ride it as is until next winter. At that point another newbie will enter Maintenance Land.
I realize that I won't know exactly the extent of the engine work required until I open it up and inspect and measure the bores etc.
My local Kawasaki shop says that OEM rings are not available. With that in mind, I am seeking the wisdom of KZR members.
If stock size rings are all that is required, what is the quality of aftermarket ones, or are OEM rings available elsewhere?
If boring and new pistons etc. are required, what are my options? I don't want to go the high compression route. I believe the Wiseco 1015 gives 10.5:1.
I see that Z1E has a limited supply of OEM oversize pistons and rings but they are pricey compared to a Wiseco kit which includes pins, clips, and gasket.
Would it be worth while to plan on boring, and stockpile OEM oversize pistons/rings, or are there other low compression options?
Will boring necessitate re-jetting the carbs?
It is a ways off until I so this work, but I am the type of guy that needs to ponder, plan, and procrastinate. Budgeting and saving is part of planning and procrastinating.
77KZ1000
76 KZ900
- otakar
14 Feb 2010 09:55 #348227
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic kz900 piston/ring options?
Z1E has the new rings in stock for your stock pistons.
www.z1enterprises.com/detail.aspx?ID=193
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
14 Feb 2010 09:59 #348228
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic kz900 piston/ring options?
otakar wrote:
Blarg! beat me to it... :laugh:
Ditto, Z1 is your best bet.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- timebomb33
- Thank you received: 10
14 Feb 2010 10:05 #348230
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic kz900 piston/ring options?
if you decide to do a re-bore the wiseco 1015 kit works very well the compression is just about perfect for street use. not so high that you'll have detonation problems, that it makes good power on and high enough that engine will make good power with premium pump gas. a win- win situation and the nice thing about is that your still using the stock block so the bike will look stock if your concerened about that
- Galactica
14 Feb 2010 19:44 #348338
by Galactica
77KZ1000
76 KZ900
Replied by Galactica on topic kz900 piston/ring options?
I intend to keep this machine for a LONG time and put a LOT of asphalt under her wheels. To that end, I would prefer to stay away from high octane fuel as long as possible.
I suppose my concern is how long will stock ring sizes and stock oversize pistons be available? Or are there aftermarket low compression units available? Or should I stock pile OEM oversize units while they are still available?
This a difficult question as I won't know exactly what I need until I take it apart. I am concerned about the dwindling parts supply. Will low compression oversize units be available in a years time?
This bike has more than enough power for me as it is.
77KZ1000
76 KZ900
- bountyhunter
- Thank you received: 337
14 Feb 2010 20:02 #348341
by bountyhunter
Replied by bountyhunter on topic kz900 piston/ring options?
I see piston/ring sets on Fleabay from time to time.
- ArthurGoVroom
- I'd rather ride it than shine it
14 Feb 2010 20:12 - 14 Feb 2010 20:17 #348351
by ArthurGoVroom
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
Replied by ArthurGoVroom on topic kz900 piston/ring options?
If for some reason replacement rings become unavailable I believe you could have Total Seal make a set of rings for the bike. They have been very good in building ring sets for oddball applications for me. You will need to know the finish bore size, the width of the ring grooves, and the radial depth of the grooves.
Last edit: 14 Feb 2010 20:17 by ArthurGoVroom.
- MFolks
- Thank you received: 540
14 Feb 2010 23:13 #348393
by MFolks
Replied by MFolks on topic kz900 piston/ring options?
This website should have a lot of Kawasaki parts:
www.excite-webtl.jp/world/english/web/?w...&wb_lp=JAEN&wb_dis=2
- Galactica
15 Feb 2010 17:18 #348514
by Galactica
77KZ1000
76 KZ900
Thanks for all the input. Gives me food for thought. Think I'll chew on it for a while, stop obsessing, and worry about it when the time comes.
That Japanese web site is hilarious. Nice stuff though.
77KZ1000
76 KZ900
- otakar
15 Feb 2010 18:58 #348543
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Since those rings that Z1E has, are repros, they should be available indefinitely. If you ask Jeff, he will tell you so. Also realize that Honda Yamaha and Suzuki all use ART pistons, you should be able to get replacement pistons for a very long time.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
