Broken clutch friction disc
  • fordtruck
  • fordtruck's Avatar Topic Author
13 Feb 2010 15:22
#348096
I pulled the clutch out today to inspect it. I really haven't been having any trouble with it, but I'm in the process of rebuilding my engine with a 1075 kit and wanted to check it out. The last friction disc to come out of the basket had about a two inch section that was broken out. The broke off piece was still in the basket. Is this common? What would cause this to happen?
I measure the other disks and they measure .150. My shop manual says to replace them if they measure less than .140, so I guess they are alright. The metal disks were glazed and showed signs of burning in spots. I sanded them with 220 grit sandpaper and they look good now.
Is is alright to just replace the one broken friction disk?
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • RonKZ650
  • RonKZ650's Avatar
Re: Broken clutch friction disc
13 Feb 2010 16:24
#348115
Probably an aftermarket clutch. Those old Barnett clutch plates did that all the time. Buy original Kawasaki plates.
  • APE Jay
  • APE Jay's Avatar
14 Feb 2010 00:18
#348179
Quite common with OEM style aluminum friction plates. That is why high HP KZ dragbikes using oem style plates take the clutch pack out every few runs and replace the broken ones.
Steel type plates like our extra plate kits don't do this.
kzzone.com/clutches.html
  • Old Man Rock
  • Old Man Rock's Avatar
14 Feb 2010 05:16
#348184
"I measure the other disks and they measure .150. My shop manual says to replace them if they measure less than .140, so I guess they are alright."...
If you're that close to tolerance... replace them for they're not that expensive really...
I replaced the OEM steel plates, friction plates and springs for $120... Definitely was worth it... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • keith1
  • keith1's Avatar
14 Feb 2010 08:15
#348209
you can replace just the one....i m with dave though...new stock stuff isnt that expensive and will work fine....new metals, fibers, and stock replacement springs and a new cable....re-adjust and you wont have to mess with it for many, many miles.....B)
  • fordtruck
14 Feb 2010 08:24
#348211
This 1075 build is just about to kill my budget, so I think I'll just replace the one disk for now. I'm not too worried about it since it's so easy to change. If I get a few thousand more miles out of it, then great.
Thanks guys!
  • otakar
  • otakar's Avatar
14 Feb 2010 08:38 - 14 Feb 2010 08:48
#348214
Actually .150" is very good. The plates start out at .157 new. You can replace just one plate. That is how Kawasaki sells them anyway. If it is an OLD Barnett "Cork" pad clutch, get rid of it. If it is an OEM clutch, they are quite good. One thing I WOULD change are the springs. They go week with in about 6-6 years. I just had to change the ons in my 81 motor because I checked them on a spring compression gauge and they were WAY under spec even though they were with in spec length wise. Get a set of EBC "326-7912" springs from Z1E they are quite cheep, about $15 or less. Week springs will ware out a clutch quite quickly due to excessive slippage.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 14 Feb 2010 08:48 by otakar.
  • timebomb33
  • timebomb33's Avatar
14 Feb 2010 10:19
#348235
just replace it your clutch pack will be fine i break the inside 2 all the time it's mostly caused by hard lanches and hooking up hard i have been using used stock clutch plates for years in fact i have a stack of of around 50 each of the fibers and steels that i carry in my race trailer for just such occasions.used plates or what i call seasoned seem to work the best for me i haven't bought a brand new set of clutch plates in over 20 years. also i dont re surface the fibers but i do beadblaST scotchbrite the steels to get any glaze of them.
I THINK MY POWERBAND BROKE
  • fordtruck
14 Feb 2010 10:19
#348236
Thanks otakar. How can I tell if it's a Barnett Cork? I will go ahead and order new springs.
  • APE Jay
  • APE Jay's Avatar
14 Feb 2010 16:35
#348290
If you put heavier springs in it, be sure you have the needle bearing pusher.
