- Thank you received: 1
Valve Tech - What's a 30 degree backcut worth?
- larrycavan
- Visitor
- polkat
- roy-b-boy-b
- Thank you received: 103
- timebomb33
I THINK MY POWERBAND BROKE
- BSKZ650
- Thank you received: 14
in my mind I figured it prob helped clean up the flow around the valve also, not sure if there is any way to teast for that.
77 ltd1000, current rider
76 kz900, just waiting
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Valve Angles - Make More Horsepower
They went as far as doing a double back cut, but it yielded no percievable results.
Not exactly bike tech, but still interesting :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- larrycavan
- Visitor
It's one of those things where you sneak up on the amount you cut as well.
Here's some numbers for you.
Stock 1983 GPz11 with much larger than KZ port and 38mm stock valves [the're back cut from the factory]
Flowed at 10" of test pressure.
.100 - 28CFM
.200 - 58CFM
.300 - 77CFM
.400 - 82CFM
.500 - 82CFM
Here's the KZ street cut I did with J Intakes and throats at 86% of valve diameter. Bowls are only 33.5mm Runners are still smaller than a J. Flowed without a radiused intake boot that generally adds 3 - 5 CFM to the numbers.
.100 - 30.8CFM
.200 - 55.4CFM
.300 - 78.0CFM
.400 - 84.2CFM
.500 - 86.0CFM
Head will get decked tomorrow and I'll post up some pics of the completed work.
It's getting married to some Cam Motion Z1 Grind cams [.400 lift with 246@.050 dur]and topped off a rack Keihin CRS29 Smoothbores and a 1075 Piston Kit. Should make a really nice street ride...
I could take this head to an easy 90+CFM no problem with 90% throats.
- Ktm181
- Man made it, so Man can fix it
For that matter i'm even keener to get it down here to Aussie and fitted to the "old girl"!!!
Kt
- Old Man Rock
- Thank you received: 225
I'm just glad I sent Larry my head to do his magic... Give me the spaghetti electrical work any day over all this CFM spanglish... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- BSKZ650
Anyone here speak Japanese for I have no clue what the hell Larry just said.... :laugh: :laugh: :laugh:
OMR
Im thinkin OMR has had too many shorts in his pants:woohoo:
- Thank you received: 2098
OMR
- Old Man Rock
Anyone notice the dead guy "Patton" in the image.... :ohmy: :huh: :dry: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
