Valve Tech - What's a 30 degree backcut worth?
- larrycavan
12 Feb 2010 16:30
Flow tested from .100" - .400"
Valves are M.I.J. Aftermarket OEM replacement 37mm J Intakes, from Z1.
The modified valve
The modified valve
- polkat
Re: Valve Tech - What's a 30 degree backcut worth?
12 Feb 2010 18:11 - 12 Feb 2010 18:13
Don't know about bikes. We did it to all our racing big block Mopars and saw as much as 10, or more CFM at lifts up to maybe .4" As I recall, cam choice and porting had a bit to do with it. Of course, those were much bigger valves.
Last edit: 12 Feb 2010 18:13 by polkat.
- roy-b-boy-b
12 Feb 2010 18:18
Thanks for sharing the info. Roy
- timebomb33
12 Feb 2010 20:26 - 12 Feb 2010 20:27
i have often wondered if back cutting the valve was actually worth any thing now i know i'm redoing a couple of heads for my drag bikes i'll be doing that before they go back together. 4 cfm is quite a bit especcally if it is free. thanks for doing the leg work, larry.
I THINK MY POWERBAND BROKE
Last edit: 12 Feb 2010 20:27 by timebomb33.
- BSKZ650
15 Feb 2010 05:26
I always back cut the valves on racing applications but never had the chance to see what difference it really made, good info.
in my mind I figured it prob helped clean up the flow around the valve also, not sure if there is any way to teast for that.
77 ltd1000, current rider
76 kz900, just waiting
- TeK9iNe
- What did you do!?!
15 Feb 2010 08:35 - 15 Feb 2010 08:44
I've looked at this a couple times and saved it.
Valve Angles - Make More Horsepower
They went as far as doing a double back cut, but it yielded no percievable results.
Not exactly bike tech, but still interesting :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 15 Feb 2010 08:44 by TeK9iNe.
- larrycavan
15 Feb 2010 16:38
Somtimes a backcut on the valves pays off and sometimes it doesn't. It depends on the port shape.
It's one of those things where you sneak up on the amount you cut as well.
Here's some numbers for you.
Stock 1983 GPz11 with much larger than KZ port and 38mm stock valves [the're back cut from the factory]
Flowed at 10" of test pressure.
.100 - 28CFM
.200 - 58CFM
.300 - 77CFM
.400 - 82CFM
.500 - 82CFM
Here's the KZ street cut I did with J Intakes and throats at 86% of valve diameter. Bowls are only 33.5mm Runners are still smaller than a J. Flowed without a radiused intake boot that generally adds 3 - 5 CFM to the numbers.
.100 - 30.8CFM
.200 - 55.4CFM
.300 - 78.0CFM
.400 - 84.2CFM
.500 - 86.0CFM
Head will get decked tomorrow and I'll post up some pics of the completed work.
It's getting married to some Cam Motion Z1 Grind cams [.400 lift with 246@.050 dur]and topped off a rack Keihin CRS29 Smoothbores and a 1075 Piston Kit. Should make a really nice street ride...
I could take this head to an easy 90+CFM no problem with 90% throats.
.100 - 28CFM
.200 - 58CFM
.300 - 77CFM
.400 - 82CFM
.500 - 82CFM
.100 - 30.8CFM
.200 - 55.4CFM
.300 - 78.0CFM
.400 - 84.2CFM
.500 - 86.0CFM
- Ktm181
- Man made it, so Man can fix it
15 Feb 2010 21:01
Great work and info Larry, cant wait to see the pics.
For that matter i'm even keener to get it down here to Aussie and fitted to the "old girl"!!!
Kt
Kt
- Old Man Rock
16 Feb 2010 03:20
Anyone here speak Japanese for I have no clue what the hell Larry just said.... :laugh: :laugh: :laugh:
I'm just glad I sent Larry my head to do his magic... Give me the spaghetti electrical work any day over all this CFM spanglish... :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- BSKZ650
16 Feb 2010 05:18
Old Man Rock wrote:
Im thinkin OMR has had too many shorts in his pants:woohoo:
OMR
16 Feb 2010 07:20
OMR
- Old Man Rock
16 Feb 2010 07:22
:laugh: :laugh: :laugh: :laugh:
Anyone notice the dead guy "Patton" in the image.... :ohmy: :huh: :dry: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
