still in search
- wildwilly30
09 Feb 2010 15:22 #347444
by wildwilly30
1977 kz1000 chopper
1974 honda cb750k chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
1981 yamaha 650 special
1983 kawasaki vulcan
1977 hd sportster chopper
1987 honda vt1100c shadow
still in search was created by wildwilly30
i need the little black pads that go on top of the cam chain idler on a 78 kz650, does anybody have some?
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
- RonKZ650
- Thank you received: 240
09 Feb 2010 16:19 #347453
by RonKZ650
Replied by RonKZ650 on topic still in search
If you're talking about the larger pads that the 4 bolts go though to mount your top center idler, part # is 92075-289
www.z1enterprises.com/SearchResult.aspx?...e&KeyWords=92075-289
If you need the little rectangular pillows that go with the 2 lower idler sprockets, part # is 92075-232
www.z1enterprises.com/SearchResult.aspx?...e&KeyWords=92075-232
Get them at Z1 enterprises or any Kawasaki dealer. Common parts.
- wildwilly30
09 Feb 2010 19:28 #347499
by wildwilly30
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
Replied by wildwilly30 on topic still in search
thanks, its the 92075-232. i noticed it says 4 required. i only had two on the idler facing the front of the bike. this right or wrong?
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
- RonKZ650
10 Feb 2010 06:22 #347550
by RonKZ650
wildwilly30 wrote:
There are two lower idlers, each one takes two so four total. Normally they are installed rubber up, but it makes little difference. They like to fall in the engine during assembly and disassembly obviously, so to hold them in place you can use a little superglue or the like to adhere them to the shaft. Early 650s just had a solid shaft on each idler. Somewhere late 77 they added the rubber as a kind of damper to quiet engine noise.
- Mark Wing
- Thank you received: 22
10 Feb 2010 08:38 #347561
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic still in search
You didn't get the one's I sent you?
Mark
Mark
Yorba Linda Cal.
- wildwilly30
10 Feb 2010 09:04 #347562
by wildwilly30
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
no i didnt. i just figured you got busy, its no problem at all. i was waiting for my head to get back from the machine shop and it got back way faster than i expected.
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
- Mark Wing
10 Feb 2010 11:28 #347578
by Mark Wing
Yorba Linda Cal.
I have more of them, I can send some more.
Mark
Mark
Yorba Linda Cal.
- wildwilly30
10 Feb 2010 15:18 #347598
by wildwilly30
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
thats ok, i really appreciate it. i already ordered them from z1 last night. i have had mail trouble lately so they could have got lost. thanks again
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
