Mixed up lifter....what could go wrong?
- KENN317
I have a 77 kz 1000 with 4 into 1 unknown exhaust, k&n pods, dyna s with 3ohm green coils. I had a head gasket leak and after taking the head off decided to clean everything up. So... I clean off the old gasket, flipped the head over and cleaned the inside. When I flipped the head back over, five of the lifters fell out. I cleaned them up, put fresh oil on them and just put them in anywhere. I went to bed started reading the manual and what do you know....."Caution: Do not mix up lifter, put them in a egg carton and label to ensure they don't get mixed up" What should I look out for? How do I fix it?:S
- Thank you received: 2098
Hey all,
After reinstalling the head and camshafts, would perform routine valve clearance checks and replace shims as needed.
Good Luck!
- PLUMMEN
- Thank you received: 104
- KENN317
- Old Man Rock
- Thank you received: 225
As mentioned, your just going to have to re-shim for spec clearances, should be alright.... As Tim mentioned & re- check the clearances it after a couple hundred miles or so...
Or... Screw Plummen, sell me the bike!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
