1075 kit question
- fcat5
- DoubleDub
- Visitor
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- DoubleDub
- Visitor
I know, I know, the cost of the sleeve is the least of it....then there's porting, valves, cams, carbs, exhaust, suspension, brakes, tires, rear sets, etc.... but I was just curious.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
What does it run to do a re-sleeve typically? I found a set of the 1015cc jugs for a variety of other reasons, but I was curious what the cost was to have this done.
to do everything on your list, you will be into a couple-few thousand dollars. To just bore and piston your stock block will be around $750+/- to re-sleeve would be another $500
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- fcat5
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Do us a favor; fill out your profile so we know a bit more about you. There might be a member in your area that might be willing and able to help you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
- Thank you received: 2
If you just want to stay with a 1015 you can get away a bit cheaper. I am quite sure that someone here might have a set of pistons that they took out of their pre 1981 KZ1000 that they will let you have very cheap. All you would do is get new rings for about $80 and have the cylinders bored by Joe Hooper at Pitstop Performance in Orlando. He charges $100 plus postage. joehooper@cfl.rr.com 407-679-9116. I have had him do a bunch of stuff for me and he is the cheapest and very good. Or you can buy a set of MTC 10.5:1 pistons from him. He will give you the best price possible on them.
i second dealing with joe hooper.....top notch guy with very good prices.....i bought a set of jugs from him alraedy bored to 1075,MTC 10.5 to 1 pistons,piston pins, buttons, base and head gasket..he also put the rings on and did all the specing out and numbered what piston went in what hole......i bought thru ebay and at the time i think the whole deal was 600 bucks......good communication
and a pleasure to deal with.....there are a lot of good
parts/motor/machine guys out there, but i havent dealt with them.....
- fordtruck
- Thank you received: 6
FYI, he has recently increased the price of a bore and hone to $124. Still way cheaper than anyone else. I checked locally and the cheapest was $200. Joe also sets the end gap on the rings and installs them on the pistons.
I can't wait to get my parts back!
'77 KZ1000-MTC 1075 kit. Stage 1 port
