Oil and compression?
27 Mar 2006 11:30 #34701 by MattBlack
Oil and compression? was created by MattBlack
OK, another newbie quesion, but when I have really rich conditions in my car, my oil tends to get watered down (or gased down I should say) and if it's left too long I can wash out the cylinders and I end up loosing compression, doing damage, what have you...
now on a bike engine, does this also happen? If you've been running real rich and flooding it out does the oil get fuel contaminated and will this hurt compression?
Thanks again - I'm learn'n. :whistle:
MB
  • wireman
  • Visitor
27 Mar 2006 12:11 #34711 by wireman
Replied by wireman on topic Oil and compression?
yeah that washes down the cylinders causing a lot of wear,it also plays hell on bearings!:whistle:
27 Mar 2006 13:19 #34718 by MattBlack
Replied by MattBlack on topic Oil and compression?
Does it also make it that much harder to get it started, just curious.
27 Mar 2006 14:43 #34734 by RomSpaceKnight
Replied by RomSpaceKnight on topic Oil and compression?
It could. Plugs could be fouled up or really really wet with unburnt fuel. Engine damage could have occurred already and there is little compression in the cylinder.
Ask in the carb forum for help on jetting and carb work, to correct rich fuel condition. Do a compression check on engine. If low put a teaspoon of oil down plug hole and try again. Compare results.
27 Mar 2006 16:57 #34758 by MattBlack
Here's a newbie realization for you....
I didn't know the kickstart wouldn't work with the clutch pulled in. :blush:
Changed the oil today (It was pretty nasty anyhow) and put in some new plugs.
I fiddled with the little adjustment knob on the carbs and in three kicks it started. Go figure. It is still running off-tune, but at least I'm getting somewhere. I thought my issues were electrical, but it really just seems like it's the carbs needing adjustments at this point.
OK, well I'm back off to the garage to do some more learn'n. :whistle:
Hopefully it won't take long for the bike-rookie in me to wear off. B)
