Valve lifter 'bucket' stuck!!
  • polkat
  • polkat's Avatar Topic Author
05 Feb 2010 17:10
#346719
Rebuilding my 750 in my KZ750H3. Was dis-assembling the head today and got all the 'buckets' off the valve spring retainers...except the very last one. Isn't that always the way it is?!
Anyway, it's stuck hard. I usually use a strong magnet to get these out, but it won't budge. It won't even turn with fingers. It's hard stuck (probably some grit in there), so I thought before I take some serious (most likely damaging) action on it, I'd ask here what others have done?? I'd like to save it if I could.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Valve lifter 'bucket' stuck!!
05 Feb 2010 18:23
#346745
Find an old computer hard-drive and bust it open.
(Any old computer shop will have some crap drives or magnets)
Inside, you will find 2 incredibly strong neodynium magnets that will pull that sucker bucket right out.
You can blast it with a torch for a few seconds first, then spray some penetrant all around the bucket, that should do it!
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • PLUMMEN
  • PLUMMEN's Avatar
05 Feb 2010 18:26
#346748
soak it down with zep45 then get an olddeep socket about same size to sit on top and smack the end of socket a couple times with a bfh! B)
  • bountyhunter
  • bountyhunter's Avatar
05 Feb 2010 20:59
#346774
I'd hose it with Kroil and let it sit overnight and see if that loosens it up.
  • polkat
05 Feb 2010 22:49
#346782
Yea, that's the kind of magnet I use. Not even close this time. I'll let it soak for a while in penatrant and see if that helps.
  • TeK9iNe
  • TeK9iNe's Avatar
06 Feb 2010 09:53
#346847
I like the socket idea Plummen.
Soak it. Swear at it for a couple minutes. Smack it!
That'all likely do it!! :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • PLUMMEN
  • PLUMMEN's Avatar
06 Feb 2010 10:11
#346850
valve spring pressure should push it back up once it goes down to free it up B)
  • polkat
06 Feb 2010 19:34 - 06 Feb 2010 19:36
#346948
Got it by Q-Bonding two strong magnets to the top. When dry, I was just able to wiggle it loose before the bond gave up. Cleaned it up with acetone. Can't find the reason it stuck (no marks).
In a related question, how have you guys modified standard valve spring compressors to fit on top of the spring retainer in these heads (which are mostly surrounded head material)? I was thinking about taking a 1" pvc junction, cutting the sides out (to get to the valve locks) and sticking that between the compressor and spring retainer.
Other ideas?
Last edit: 06 Feb 2010 19:36 by polkat.
