Bolt above gear selector
- KLD
05 Feb 2010 12:27 - 05 Feb 2010 12:30 #346671
by KLD
Bolt above gear selector was created by KLD
I'm almost done rebuilding this 73 z1. I added in oil to see if the pan would seal and to check for leaks and well the pan isn't leaking, but oil is coming from somewhere behind this cover. I don't want to just take the bolt off without knowing what it is, it looks as if it has been adjusted many times. Maybe someone has had a similar leak
Last edit: 05 Feb 2010 12:30 by KLD.
- jeffasaki
- Thank you received: 44
05 Feb 2010 12:47 #346680
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic Bolt above gear selector
Thats the clutch release adjustment assy.There is a oring on the actuator rod behind the cover.I think this is the only place engine oil could come from.You have to remove the cover to access it.Only 4 bolts and you can leave your cable assy all hooked up.Easy
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- KLD
05 Feb 2010 16:52 #346715
by KLD
Replied by KLD on topic Bolt above gear selector
Ah, Yea I got to looking and the oil is definitely coming from where the actuator rod going into the transmission. Do they sell a replacement o-ring for it? I failed to find it on z1e
- PLUMMEN
- Thank you received: 104
05 Feb 2010 17:05 #346718
by PLUMMEN
Replied by PLUMMEN on topic Bolt above gear selector
its actually a seal,i dont remember if you can change it easily from outside.if it isnt leaking too bad maybe try riding it a little and see if the seal swells back up after having some oil on it.
- KLD
05 Feb 2010 18:08 #346740
by KLD
Ah.. it leaks enough.. probably a 4x4inch puddle each night. Don't want to waste that expensive supertech oil thats in it ya know . Good call on the swelling, we'll see if it does.
- TerryK
- Thank you received: 3
05 Feb 2010 19:33 #346760
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Bolt above gear selector
I'm pretty sure you can change that seal from the outside. Just remove the countershaft sprocket cover and you'll see it.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- PLUMMEN
05 Feb 2010 19:41 #346761
by PLUMMEN
im thinking the trap door over shift linkage needs to come offto get at it
