Gasket sealent for cams
- pg4827
27 Mar 2006 08:29 #34666
by pg4827
Gasket sealent for cams was created by pg4827
On the cam shaft end plugs what type of sealent is used to hold them in? And do you use sealent on the cam cover gasket?
- OKC_Kent
- Thank you received: 20
27 Mar 2006 08:51 #34673
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Gasket sealent for cams
I smeared a thin film of high temp sealant, whatever was on my toolbench. I believe it was Permatex, an orange color..it may have been the hi temp copper sealant. They don't leak. And I applied a thin film of grease to both sides of the cam cover gasket, and it's not leaking either.
Oklahoma City, OK
