- Thank you received: 1
Dang! Burning oil!
- polkat
03 Feb 2010 16:49 - 03 Feb 2010 16:51 #346298
by polkat
Dang! Burning oil! was created by polkat
In a recent post I asked what to do about an engine that smoked from running rich. The responses I got all suggested that it was oil burning. I was stubbron about this until finally today I pulled the plugs and inspected the piston tops with a peak light I made. Well, not only were the plugs all oily, but the piston tops and some intake valves I could see where oily too.
Okay, I was wrong and admit it. It's burning oil. I don't know if it's the valves or rings, or both yet. Now what to do about it? I can do the work no problem, but I live in a remote area with limited tools. So, can I pull the head and possibly the cylinders without removing the engine from the frame? If so, what do I do about the cam chain, etc?
Any advice will be most appreciated!
Last edit: 03 Feb 2010 16:51 by polkat.
- timebomb33
- Thank you received: 10
03 Feb 2010 16:55 #346300
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Dang! Burning oil!
dont pull anything apart yet, double check your oil level and also do a compression and also a leak down test to verify where the problem is from. some of the symptoms you have described here and the carb thread would have me looking at a problem with the float valves in stead of a bad engine. if the oil level is too high or even if it'
s right pull the filler cap and give it a good smell it shouldn't smell like gas.
- polkat
03 Feb 2010 17:08 #346304
by polkat
Replied by polkat on topic Dang! Burning oil!
Oil doesn't smell like gas and the level is correct. The pugs and cylinders also smell like oil and not gas. I'll do a compression test tomorrow but don't have a leak down tester.
- Thank you received: 2098
03 Feb 2010 17:28 #346312
by Patton
Replied by Patton on topic Dang! Burning oil!
No eBay APP ID and/or Cert ID defined in Kunena configurationIf not already on hand, a FSM is essential, and readily available at reasonable cost.
Here's an example:
Good Luck!
Here's an example:
Good Luck!
- Old Man Rock
- Thank you received: 225
03 Feb 2010 17:31 - 03 Feb 2010 17:31 #346313
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Dang! Burning oil!
It's definitely oily versus carbon build up you're seeing?
"I don't know if it's the valves or rings,"... As mentioned, compression and leak down test will provide the answers.... For the most part anyways...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Feb 2010 17:31 by Old Man Rock.
03 Feb 2010 17:35 #346314
by Patton
The reported oil condition might result from worn valve seals, which usually isn't a critical issue.
Good Luck!
Good Luck!
- timebomb33
03 Feb 2010 18:02 - 03 Feb 2010 18:03 #346326
by timebomb33
just check everything over ahead of time as good as you can just to mabye keep you from tearing down a good running bike for no reason they aren't cheap to build. by the way leakdown testers are reasonably cheap. it could save you a whole pile of time and money and yes you can take the top end off in the frame.
Last edit: 03 Feb 2010 18:03 by timebomb33.
- polkat
03 Feb 2010 21:34 #346353
by polkat
I don't have a leak down tester as I said (and I'm poor). I have a manual if I can find it.
What is considered acceptable compression for this engine (KZ750H3)?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 Feb 2010 04:02 #346362
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Dang! Burning oil!
What! I believed in you man! :laugh: :laugh: :laugh:
Oh well, can't be right all the time.
Heck maybe its just time for a teardown.
You can do all the top end real easy, with the engine in the bike.
Pull of valve cover.
Pull out cams.
Take off head.
Lift off block.
Inspect all clearances/bore dimensions/pistons.
Send head + new valve seals off to have valves reground/lapped, head freshened up.
Install new rings.
Drop block back on pistons.
Install new head gasket. Put new head on.
Install cams.
Check then get new shims / set valve lash.
Install valve cover.
Run it.
Retorque it
RIDE IT!
Only a few small easy steps are in between, but for the most part it's fairly straight forward!
Good luck man!
Pull out cams.
Take off head.
Lift off block.
Install new rings.
Install cams.
Run it.
Retorque it
RIDE IT!
Good luck man!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
04 Feb 2010 04:21 #346364
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- polkat
04 Feb 2010 15:34 #346475
by polkat
Did the compression test this morning. Worst was #1 which read 110lbs. The best was #4 which read 130lbs. The other two fell at about 120lbs.
Note: ALL cylinders came up about 20lbs. when I squirted some oil in the cylinders before taking a second reading. So, I think it's time for at least a top end rebuild. Anyone agree?
- jeffasaki
- Thank you received: 44
04 Feb 2010 15:39 #346478
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic Dang! Burning oil!
when it comes up after putting oil in its pointing to rings
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
