The BIGGEST hesitation I have ever experienced
- indianken
Carbs still off so I will check by blocking the air passage as you suggested.
Thanks,
Ken
- Thank you received: 2098
- indianken
Thanks,
Ken
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- indianken
thanks
Ken
- nads.com
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- TeK9iNe
- What did you do!?!
- Thank you received: 28
You got 13+ volts at those coils???
No seriously though, man, your running the bike real lean.
As per suggested...
1 size up on the pilots, then tune your air screws.
If everything is as clean as you say, then turn ALL your air screws about 1/2 turn at a time, at the same time.
Blip the throttle half. If the revs fall down below the idle rpm add more air (counter-clockwise), if it hangs slightly above add more fuel (clockwise). Turn them all in equal increments. Afterwards, you can turn them 1/4 or so either way listening for highest idle.
This I find is the best way to get a nice quick off idle response.
Needle clip on 4th slot down.
Main should be around a 115 to prevent the power curve from arcing down after half throttle.
You will have to experiment with mains/needle for best power delivery, then your done.
DONE. Like dinner.
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- nads.com
my bike, 1015cc ported and cammed, never hesitates with no filters at all, never. I used a 112 jet and 17.5 pilots and it never hesitated. Shouldn't be any reason to change the clip, once u get people doing that it's more confusion and problems with jetting. I have seen where spark was weak and choke helped it run better. He seems to be aware of the passages in the carb and says they are clean. If it has no power it may be the timing and a compression test is in order. If air spits out the carb at the end of the intake stroke, timing needs to be checked....Coil mod... :laugh: :woohoo: :laugh:
As per suggested...
DONE. Like dinner.
Cheers!
- nads.com
JUst noticed compression is good on this engine. It should not be so lean it only runs on choke. Something is not right here. Are the needles stock?TeK9iNe wrote:
As per suggested...
DONE. Like dinner.
Cheers!
- indianken
Not having any pilot jets at hand, I took out my old set of jet drill I've had since the 60's and took a stab at resizing the stock 17.5 pilots and drilled them out to .030". I reassembled the carbs and installed them on the engine.
With fingers crossed and fuel and full choke on I hit the starter. Heaven!! started on the first little pressure put on the button and happily idled at about 2000 rpm cold. I shut off the choke as soon as the rpm started to rise and she then dropped to a steady 1200rbm idle. A little turn on the idle adjuster an she was now happily purring along at 900 rpm.
I pushed the bike out side for the real test. Having never making it past my mail box before either stalling or needing to slip the clutch at 5000 rpm to keep from bogging out, away I went. This time she accelerated away as sweet as can be. I only did a short five mile loop as the temperature here was in the mid 20 degs Fahrenheit.
So for so very good. When the tempature comes up into the 30s I will try a longer loop to see if getting the engine hotter causes any need for further adjustments, but for now I'm very VERY happy with the performance I have. So happy that today I made arrangements with my painter do repaint all the fiberglass body work.
Once again thanks for the great response from this group
Ken Smith
- indianken
Altitude 500ft. mains 117.5 needle clip 4 down
Thanks,
Ken
