- Thank you received: 2
Oil leak found...now what?
- keith1
21 Mar 2010 17:57 #355301
by keith1
Replied by keith1 on topic Oil leak found...now what?
very simple and kits to fix are all over the place...
- Thank you received: 2098
21 Mar 2010 20:49 #355330
by Patton
Replied by Patton on topic Oil leak found...now what?
Patton wrote:
Here's another pic of the seal, showing the tiny spring which surrounds the seal.
[Click on image to enhance view.]
...The rubber shaft seal includes a tiny fine spring to help grip the shaft spinning around inside the seal... the seal prevents oil from escaping along the shaft...
- sft1662
21 Mar 2010 22:11 #355345
by sft1662
1978 KZ650 B2A
Replied by sft1662 on topic Oil leak found...now what?
Thanks guys.
I think I'll start by just buying the seal from Z1 for about $2.50 and seeing if that works...
Maintenance goal for this week - - - Stop the tach leak!
1978 KZ650 B2A
