Question fo Jeff @ Z1E
  • 650ed's Avatar Topic Author
01 Feb 2010 07:29
#345817
Jeff,
Kawasaki.com database says standard KZ650 rings "Part #13008-059" are still "active." Is this true or just a mistake in the Kawasaki database? I ask because member "Scatdrat" and possibly others are trying to find stock rings. Ed
  • Kawickrice
  • Kawickrice's Avatar
Re: Question fo Jeff @ Z1E
01 Feb 2010 07:35
#345818
I to would like stock rings for a 650
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • otakar
  • otakar's Avatar
01 Feb 2010 07:47 - 01 Feb 2010 07:50
#345819
You can get rings from Hastings. They would be quite cheep. You can give them a call and they will set you up. They are 62mm 1.5mm 1.5mm 2.5mm The only thing that you will have to do is reuse your oil spacer ring because their smallest is a 2.8mm I call hastings and have the rings the next day. You even have a choice between Chrome Molly or standard Iron. #4807 or #2C4807
www.hastingsmfg.com/RingFinderDiametrica...s.aspx?AppMACD=2.441
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 01 Feb 2010 07:50 by otakar.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
01 Feb 2010 08:01
#345821
Thanks for the info otakar. B)
I think you've made a lot of 650 owners happy.
If anyone orders a set, let us know which ones you've ordered and how it works out.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • otakar
  • otakar's Avatar
01 Feb 2010 08:22 - 01 Feb 2010 08:31
#345825
I have a set in my 1150 (obviously a bit larger)I use the Chrome Molly ones you have to be more careful with them because they will deform if you are not. The Iron ones are more forgiving but if you stretch them too far they snap. for your bike they are $87 for the Chrome ones, which is what I would recommend. This is for a complete set to do all 4 pistons.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Feb 2010 08:31 by otakar.
  • otakar
  • otakar's Avatar
01 Feb 2010 08:29 - 01 Feb 2010 08:30
#345826
I looked them up and found that the standard is not available from Kawasaki (13001-1002) but the .040 is available. The rings last were $65 for one set = $260 :ohmy:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Feb 2010 08:30 by otakar.
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
01 Feb 2010 17:50
#345924
I hope this isn't considered highjacking the thread but I also have a question for Jeff. I need to get 8 new circlips for my 650. I see that you have them for a KZ1000 but not for the 650. Or at least they aren't listed under the 650 motor. Are they the same??
P.s. thanks for the hastings info. I found a bunch of stuff for old tractors I restore that I couldn't find anywhere else.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
01 Feb 2010 18:33
#345937
13008-059 are the stock size rings for the earlier 650's - they are still available (at least as of December...). a little over $200 for enough for 4 pistons.
13001-1002 are the stock pistons - and they are discontinued.
92036-005 - these are the pin clips for the 650's - still available. These are different to the Z1/KZ1000 version.
  • otakar
  • otakar's Avatar
02 Feb 2010 04:40 - 02 Feb 2010 04:49
#346003
Correct me if I'm wrong. You show your bike as a 1977 KZ650 C1. Kawasaki shows that as rings 13024-060 only available as .040 oversize in limited quantity.
My apologies. It is just the 77 page that is screwed up. When the later model pages are accessed than the proper #s pop up. in as much as the available 13008-059. Still, that price is a killer. The Hastings rings would still be my choice. If for no other reason than the price.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 02 Feb 2010 04:49 by otakar.
  • Kawickrice
02 Feb 2010 09:51
#346049
Not trying to hijack but I have a question for Jeff.
Seems like every time I place an order, I always forget something. Since I have two KZ's and a GS Its easy to forget something, maybe I should write things down better. :) With that being said a "wishlist" option on your web site sure would be handy for absent minded people like my self. Would it be feasable to add a function like this to your website or would it be more problems than its worth. Sometimes if I am not fast enough my shopping cart disappears and I have to go find every thing again and I always miss something. This is not a complaint just a question
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Jeff.Saunders
  • Vendor
  • Vendor
02 Feb 2010 13:24
#346093
The current web site software is going to be replaced later this year with a significant upgrade. 'Wishlist' is one major capability. The web site will also handle better pricing discount options for volume purchases. AND one we've been asked for a ton of times, the ability to order items currently out of stock (or get notified when they become available).
We've outgrown the current web site. When we setup the current version of the web site, we had 200-300 parts for sale. Now we have over 4,000 parts on the web site - and will likely have over 5,000 parts by the end of the year...
In addition to the wishlist, additional selection filters will be available to help refine searching thru page upon page of parts.
For example under brakes we'll have a series of pull down filters - with you able to select from one or all of them.
Select brake hose from a list of hose, fittings, pipe, etc
Select fitting type: Chrome, Stainless, Black Anodized
Select color: Clearcoat, Black, Red, Blue
Select length range: under 10", 11-20", 21"-30", etc
  • otakar
  • otakar's Avatar
02 Feb 2010 13:25
#346094
Yes Jeff i agree, a wish list on a login page would be fantastic. I have the same problem.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
