Tight clutch
- AnxiousCowboy
31 Jan 2010 18:31 #345737
by AnxiousCowboy
Tight clutch was created by AnxiousCowboy
Just got my bike back from the shop and rode it home fine. Next night it got really cold and snowed here in Brooklyn and has freezing out since. I went to start the bike and I couldn't pull the clutch lever in, it's really tight. I tried adjusting the cable where it goes into the lever with no difference. Could it have frozen somehow? Is there a different kind of adjustment that I need to make?
- chance
- Life long biker/
31 Jan 2010 18:39 #345740
by chance
Replied by chance on topic Tight clutch
Sounds like a cable ...
- AnxiousCowboy
31 Jan 2010 20:02 #345756
by AnxiousCowboy
Replied by AnxiousCowboy on topic Tight clutch
what about the cable? I need a new one or need to make an adjustment?
- chance
- Life long biker/
01 Feb 2010 06:57 #345810
by chance
If the cable is froze a new one .But you need to check and see if the cable slides easy in its cover..Mine was hard to pull and thats what it was. Sometimes you can get some lube in the cable and loosen it.Just make sure the cable slides in and out easily. Theres an adjustment under the little cover on your sprocket cover but I doubt thats what it is.Do you keep your bike outside??
- Thank you received: 2098
01 Feb 2010 07:04 - 01 Feb 2010 07:09 #345811
by Patton
Replied by Patton on topic Tight clutch
Neat little tool - - -
www.z1enterprises.com/detail.aspx?ID=2858
Perhaps start with some PB Blaster.
And the over-night-oil-funnel-drip method may also help.
Good Luck!
Good Luck!
Last edit: 01 Feb 2010 07:09 by Patton.
- AnxiousCowboy
01 Feb 2010 07:25 - 01 Feb 2010 18:47 #345816
by AnxiousCowboy
yeah, it's outside.
It warmed up tonight considerably here in the bk and the bike started right up and the clutch is fine. Guess it was THAT cold
Last edit: 01 Feb 2010 18:47 by AnxiousCowboy.
