Worrying noise..need help
- zollie
- I don't wan't a pickle, I just want to ride my...
As per my "intro" thread ( kzrider.com/index.php?option=com_kunena&...w&catid=10&id=344680 ) I bought a Z750, [Engine number starts: KZ750ee..] about a month ago.
She is in real bad shape.. If I pull away hard in First it makes a quite worrying "cluck cluck" noise.. Checked sprockets just in case - seems alright, the noise is coming from the motor, definitely. Not sure if it is the gearbox,selector or something else.
I'm going to open her up, and I'm desperately looking for an Service manual, *cough* cough..if someone might help it would be much appreciated!
Thanks and regards,
Zollie
Kawasaki Z750 - 1981 ... I think... trying to trace vin number...
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- BSKZ650
- Thank you received: 14
Also a compression check should be done.
at the very least this should give you a good picture of your engine and help determine any issues that may pop up
77 ltd1000, current rider
76 kz900, just waiting
- bill_wilcox100
- Thank you received: 5
I would not be surprised if the HYVO primary chain and or the Cam chain are slapping due to un-even firing again due to poor tuning.
The good news is that this is mostly work and not necessarily a parts and money issue... yet. I eliminated this symptom on my bike with very careful attention to tuning.
Yes you very, very much need a FSM.
Best of success,
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- zollie
I probably should've been a bit more descriptive
I bought the bike with this problem - my other bike blew Rectifier and needed some 2 wheels desperately, hehe.. And as the 750 two stroker features in the Joe Barr Comics (which I'm a huge fan of) I couldn't resist this Z :silly:
It is definitely a mechanical noise, something slipping / gear box stuffed. I had an almost similar noise on previous bike and ended up replacing a few gears. Had it at an shop and also told me that it is probrably the primary chain, but if this slips, wouldn't it cause serious problems to the motor/valves or somehitng??
I'm desperately trying to locate an manual if someone might assist..
Also is there a "map" to link VIN / Enginge num to model number?
Thanks again,
Zollie
- MFolks
- Thank you received: 540
www.motoverse.com/tools/vin/kawasaki.asp
- zollie
Hmm see the primary sits right in the middel..
Ow well... no point having it easy I guess
let the fun begin ! :woohoo:
- zollie
Try this:
Thanks, but didn't turn up any results..
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- bill_wilcox100
For the record, Z's don't have a primary chain. The chain you are referring to is the cam chain.
:huh: Mine does... HYVO connecting Crank Shaft to Transmission. :blink:
But maybe it's just mine.:blink: :laugh: :laugh: :laugh:
Best of success,
Bill
Upgrades:
Montreal, Canada
- Thank you received: 2829
What?? Please see part #13122-007. Without a primary chain the bike isn;t moving.
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
