base gasket leak
- dvjoiner
- PLUMMEN
- Thank you received: 104
- dvjoiner
- PLUMMEN
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Thank you received: 2829
- PLUMMEN
- saxjonz
- KawboyZ
- Thank you received: 76
I spoke with a few people and they said they used to sell the two pieced head gaskets. This time around I will cut the gaskets so I can use the stock o ring. You may want to consider cutting the gasket to use the rubber oring. Just a thought.
79 LTD B3
- keith1
Studs for sure. With all the disassembly you've been doing chasing the leak, the stockers are probably stretched past the max tolerances anyway. My 1075/10.5 hasn't leaked a drop with APE studs and nuts.
hd studs with nuts make a tight 42 ft/lb sandwich.....
- Kawboy74
- Thank you received: 52
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- mark1122
- Keep twisting it
- Thank you received: 109
I agree with making sure u have adaquit venting as well.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
