tach
- leitrum
tach
26 Mar 2006 08:58
tach doesn't work,how can i test if its the cable or tach so i don't have to buy both.
- btchalice
Re: tach
26 Mar 2006 09:06
unhook the cable from the tach and start the motor if it spins its the tach unless its electric
Post edited by: btchalice, at: 2006/03/26 12:07
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- leitrum
- xstreamcanadian
- rstnick
Re: tach
28 Mar 2006 06:43you can also run your tach with a drill.....
Remove the engine end of the cable and attach it to a drill, then spin away. Careful of the direction of the drill, forward or reverse, don't know firsthand which way it's supposed to go. Look at the cable while doing the cable test:"unhook the cable from the tach and start the motor if it spins ", to check for direction. You can use a spare cable if you don't want to disconnect the engine end.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- kevco
