Kick starter doesn't always engage?
- jimmyfinski
23 Jan 2010 15:04 #344115
by jimmyfinski
Kick starter doesn't always engage? was created by jimmyfinski
Hi,
My first kick on the kick start always grabs, but subsequent kicks do not turn the crank. After a few minutes of rest I am able to try again, but only once or twice. I AM in frigid Wisconsin, so is this just a temperature issue? The starter has been disconnected, and I'm trying to get this running before it gets warm so I can ride.
This is on what I was told was an '82 KZ750 twin. After replacing the ignition coil, point and condensor, and setting the timing, I quickly learning this is not an '82, but I have no idea what year it is. It has been heavily modified as well.
Thanks,
Jim
Thanks,
Jim
- MFolks
- Thank you received: 540
23 Jan 2010 15:23 #344120
by MFolks
Replied by MFolks on topic Kick starter doesn't always engage?
Can you post the engine # ? it will help figuring out what you've got.
The websites www.750twins.com and www.armbell.com/forum/viewforum.php?f=43...204ac29&mforum=kz400 are other help sources.
- Thank you received: 2829
23 Jan 2010 15:27 #344122
by 650ed
Replied by 650ed on topic Kick starter doesn't always engage?
Forgive what may be a stupid question, but you're not pulling in the clutch when you kick it over - are you? Ed
