cylinder not firing
- irish mike
- 79 kz 650 b3 rat rod
23 Jan 2010 14:30 #344112
by irish mike
Replied by irish mike on topic cylinder not firing
well i found part of the problem-the pilot jet on carb#3 came loose[must have been that idiot that worked on the carbs-woops that was me ]well cylinder #3 fires now but with alot of white smoke from the exhaust-i have noticed that #2 is not getting very hot now -i think its a coil problem too-can i use the coils that go with the dyna ignition on a points system or only on the electronic ignition-i eventually want to go to electronic ignition but right now money is a little tight thanks again all ...mike...
- roy-b-boy-b
- Thank you received: 103
23 Jan 2010 16:06 #344129
by roy-b-boy-b
Replied by roy-b-boy-b on topic cylinder not firing
You can use the dynas on a points bike. Roy
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 Jan 2010 16:27 #344139
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic cylinder not firing
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
