- Thank you received: 1
Strange oil leak?
- polkat
(the image is just one I grabbed off the web as my camera bats are dead)
It doesn't appear to be coming from the cam cover above or to be under any pressure. It seems to be coming from the junction of the bottom of that cylinder and the case. I plan to rebuild the engine next summer, but I am wondering of I can put some kind of sealant (maybe hi-temp silicon) in there as a temporary fix?
Any ideas?
- RonKZ650
- Thank you received: 240
- Bluemeanie
- Thank you received: 14
KZ650/750 are full of rubber orings. There's rubber orings that seal the cylinder to the block where the oil passages go up each side. My guess is the rubber rings have hardened and started leaking. You can use silicon possibly. I've done it and it's kind of a mess, but does the trick for a while at least.
Use some brake clean (evaporates) and clean it real nice, go for a short ride and when you get back you should see exactly where it's coming from. Clean again and apply with your finger some good (usually "black" silicon is oil resistant) quality silicon along seam line 1-2 inches on either side of leak. Remove excess and let sit overnight and it should hold for quite a while. Can easily be reapplied if necessary to hold until re build.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- JMKZHI
- Thank you received: 48
The grommet is on the lower rearward side. I don't believe the 750H should have oil behind the that cover.Could it possibly be coming from the grommet at the bottom of the cover where the wires for the stator exit the cover? ...
- polkat
- gane
[img][/img] 1977 KZ1000A1
- polkat
- Thank you received: 2098
I prefer the foot spray because it seems to contain more power residue.
While at it, after cleaning engine and allowing to dry, would also spray around all usual suspects (cam plugs, valve cover gasket, head gasket, tach drive, exhaust clamps, base gasket).
Then crank and run the clean freshly powdered engine for a few moments to detect the seepage areas.
Good Luck!
- Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Old Man Rock
- Thank you received: 225
Actually 2.... :blush:
Torques on the cylinder stud nuts and in this case, the side bolt in the image between the 2 cylinder studs have been checked/tightened/confirmed?
Is the oil leak coming for that side bolt... Clean oil is hard to detect. I had similar in my new engine build... Once I got some miles on the engine, Dyno oil at the time darkened and this is where is was coming from...
NOTE: On new builds, this is somehwat expected where bolts loosen... As provided to me... 50-500-1000 mile checks, torque every single bolt on the engine and frame to torque specs....
Just a thought....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
