Frankenbike has hollow cams
- School Teacher
17 Jan 2010 23:20 #343310
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Frankenbike has hollow cams was created by School Teacher
Well i bought a 76kz and was tearing it down as the thing is becoming a donor for parts and my first supprise was that i had honda pistons in it. i guess it made it like 1038? any way i was gonna ebay it and then found the cams that were in it. they are hollow, from what i gather they were off an 73ish bike? they are stock lift as far as i can tell the thought the grind looks slightly different(duration?). anyone know if the grind changed with the hollow cams vs solid? And also i have neve seen a pair on ebay do they break easy?
1980 kz1000G1
- kaw74z1
- 0 to 60 in 15 minutes.
17 Jan 2010 23:54 #343311
by kaw74z1
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Replied by kaw74z1 on topic Frankenbike has hollow cams
u2u sent
- Old Man Rock
- Thank you received: 225
18 Jan 2010 04:22 #343315
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Frankenbike has hollow cams
Hollow, as in all the way through the cam shafts???? :ohmy: :blink: :woohoo:
Ok, you have my interest...images please....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Jeff.Saunders
18 Jan 2010 04:38 #343319
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Frankenbike has hollow cams
They came on 73 and early 74 Z1's. Kawasaki drilled all the way from end-to-end. Probably to reduce weight on the cam components.
I've never seen one break - although I'm sure they could if you dropped them...
Z1 Ent on Facebook,
- kawsakiman
- Thank you received: 6
18 Jan 2010 20:15 #343462
by kawsakiman
Replied by kawsakiman on topic Frankenbike has hollow cams
i have access to a set.
jeff beat me to it.73 z1 cams. great for a turbo application.
who wants to start the bidding? :lol:
i'll see if i can get some pictures this weekend.
- School Teacher
19 Jan 2010 11:41 - 19 Jan 2010 11:44 #343527
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic Frankenbike has hollow cams
1980 kz1000G1
Last edit: 19 Jan 2010 11:44 by School Teacher.
- Old Man Rock
19 Jan 2010 12:50 #343534
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
We'll I'll be damned....
One would think of the applied [pressures & torques being applied to this shaft, the damn thing would just twist in a swirl with hard throttle/compressions/torque loads...
Learn something new everyday.... Thanks for sharing.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- Thank you received: 104
19 Jan 2010 14:33 #343548
by PLUMMEN
Replied by PLUMMEN on topic Frankenbike has hollow cams
havent ya ever seena "gun drilled " crankshaft on a car before? lots more load on one of those than that little ol camshaft!
- KTA
20 Jan 2010 02:54 #343585
by KTA
Replied by KTA on topic Frankenbike has hollow cams
Wow - what a cool cam. I've never seen seen one before, but have heard rumors. I'd be curious to know the difference in temperature that this cam runs at compared to a solid unit. Can't be much different, but probably a little.
- T_Dub
- Thank you received: 25
21 Jan 2010 17:29 #343791
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Frankenbike has hollow cams
The torsion stress in a shaft increases linearly from zero at the centerline to the maximum at the surface. And this maximum decreases as you make the shaft larger. So, if you make the shaft a little larger and hollow, you can have it take the same torque loads and it'll be much lighter. Thats why a driveshaft in a truck has a large diameter and thin walls. You could do the same job with a solid shaft, but since the load at the center is close to zero, you have a lot of material that isn't being used to carry load, so it ends up weighing too much.
All the new sportbikes have hollow cams, with plugs.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- APE Jay
- Banned
- Thank you received: 58
22 Jan 2010 14:00 - 22 Jan 2010 14:02 #343968
by APE Jay
Replied by APE Jay on topic Frankenbike has hollow cams
Years ago (Why does it seem I start every post like that ), Yosh used those hollow cams modified by plugging the ends and drilling some holes in the bearing surfaces to get oil into the center, then had holes in the lobes to squirt oil directly on the bucket as the lobe came around.
Today, all of the modern sport bikes have hollow cams.
Last edit: 22 Jan 2010 14:02 by APE Jay.
- Old Man Rock
22 Jan 2010 14:05 #343969
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Jay...uhm... when can we expect APE to start offering these
hollow cams with bucket squirts?...
Don't know about anyone else but Luv that idea...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
