- Thank you received: 1
Exhaust collars (KZ 750)
- Ituen
- Rider
17 Jan 2010 20:52 #343303
by Ituen
1982 KZ750 E
Kawasaki Rider
Exhaust collars (KZ 750) was created by Ituen
I was looking at the exhaust collars on my bike. Is there a better way to secure the header to the cylinder head? I was thinking about a flat flange on the head. Is there a exhaust gasket to trace and make a flange to bolt a custom header on?
1982 KZ750 E
Kawasaki Rider
- MFolks
- Thank you received: 540
17 Jan 2010 20:58 #343304
by MFolks
Replied by MFolks on topic Exhaust collars (KZ 750)
Remove your exhaust system, and there should be a gasket between the end of the header and the engine's exhaust port.
Or order a new one(s) from www.z1enterprises.com
- JMKZHI
- Thank you received: 48
18 Jan 2010 08:35 - 18 Jan 2010 10:15 #343339
by JMKZHI
Replied by JMKZHI on topic Exhaust collars (KZ 750)
So, the exhaust header tips are flared?
You may need to get the half-moon exhaust collars from a 70s KZ650 & maybe an 80 model. Those bikes have the flared tips & the exhaust collars are longer/deeper.
Just in case... the stock exhaust pipes on your bike have a flange welded to them & the collars are shorter. The 81-83 650CSRs have the same collars as your bike.
Last edit: 18 Jan 2010 10:15 by JMKZHI.
