trying to revive my totaled kz1000
- knibbeone
1982 KZ1000 LTD
- BSKZ650
- Thank you received: 14
Maybe a couple of pics might help, there are some shap cookies on here who can prob point you in the right direction, and poss a good source for parts
77 ltd1000, current rider
76 kz900, just waiting
- roy-b-boy-b
- Thank you received: 103
Parts are going cheap on eBay and you can get a single gasket for it.
Roy
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
If it leaks when it is running then shut it down and find the leak.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- will61310
- Thank you received: 6
...1980 LTD 1000...
- muddy1
- 1980 Kz1000 LTD B4
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- keith1
- Thank you received: 2
if the scrape made a hole in your case, there could be metal doo doo inside....maybee a rock or two:S
exactly what i was thinking...i would pull the cover and scope it out inside......not hard or time consuming....
- gane
[img][/img] 1977 KZ1000A1
- hardr0ck68
Do the liter bikes run oil in the stator cover? I had not heard of a "wet" stator before.
I guess I thought they were like the 650's and the crank seals kept the oil in the cases.
1977 kz650 c1
- MFolks
- Thank you received: 540
These engines had low oil pressure(2.8-3.00 PSI) due to roller bearing crankshafts.
- Old Man Rock
- Thank you received: 225
"left side cover that sticks out is ground off by the pavement."... Pictures would definitely help so assumption is ground through the cover thus hole thus YUP, leak...
A bigger concern is that it may have ground into the stator windings thus shorted windings thus no good, no worky.... If indeed shorted windings then possibly damaged rectifier/regulator circuit due to short. Sorry, not trying to ruin your day further but these are likely possibilities you need to check/measure/confirm.
Visually inspect no doubt is in order... Electrical resistance, voltage and current measurements would be wise...
No worries, these stators, rectifiers & regulators are available... Z1, APE, other KZ locations... Cases are available as well.... All can be repaired!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
