750 4 Engine Rebuild Info?
- TattooMark
10 Jan 2010 18:24 #342506
by TattooMark
750 4 Engine Rebuild Info? was created by TattooMark
Does anyone have any info on rebuilding a 750 4? Maybe places to get parts... where to find the best prices... maybe a walkthrough... anything will help. I have really low compression, somewhere around 80psi in one and four and 40psi in two and three so I figure I will just rebuild it and not have to worry about other stuff down the road... Thanks
- TerryK
- Thank you received: 3
10 Jan 2010 18:42 #342514
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic 750 4 Engine Rebuild Info?
Have you checked the valve lash? It's possible a simple shim adjustment will bring your compression back up.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Bluemeanie
- Thank you received: 14
11 Jan 2010 05:49 - 11 Jan 2010 05:50 #342545
by Bluemeanie
Replied by Bluemeanie on topic 750 4 Engine Rebuild Info?
TattooMark wrote:
When you did the compression test, did you have all plugs out and throttle wide open? Also, squirt a little oil in cylinder and repeat test. If it goes up it's your rings. If it stays the same it's in your valves (or valve adjustment as TerryK says) Let us know...
Last edit: 11 Jan 2010 05:50 by Bluemeanie.
- bountyhunter
- Thank you received: 337
11 Jan 2010 16:26 #342609
by bountyhunter
Replied by bountyhunter on topic 750 4 Engine Rebuild Info?
Valves is the most likely culprit. Either clearance too tight or they need to be lapped and ground.
