- Thank you received: 1
Advancing factory cams?
- Becker
- The Doctor Will Rise Again
KZ1000 intake cams: open 30 degrees btdc, closes 70 degrees abdc, total duration of 280 degrees.
So
280 (duration) / 2 (to find the center) =140 degrees
140 (center of cam lobe) - 30 (degrees btdc has to be subtracted to get where the center is compared to the crank??) = 110 degrees atdc (lobe center??)
A good mod for stock bikes both suzuki gs and kz kaws, is to bring lobecenters down to 104 to 105 intake and exhaust.
So thats a 5 degree difference and it makes that big of a difference?? Can I do this to my 650?? This is very interesting.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- PLUMMEN
- Thank you received: 104
- nads.com
- Thank you received: 20
I don't know the centers he spoke about but If I had to guess, I think they would be more intake advance and more retard on the exhaust. The valve to piston clearance is minimum when at 105 intake so anything from there may require deepening the valve releif pockets on the piston so the intake doesnt hit it. Probably the same on the exhaust. It's just a guess but I'm going to assume Dale was trying to get the torque to increase, which helps off the line and through the quarter mile. If you overrev with 105 centers it's likely you'll bend a valve, since they are close to the piston. Valves actually float alot earlier in the rpm then realized, they just have enough clearance not to hit the piston. New valve springs can be the best tune up for an engine turning some rpms. From the time you start the motor to making a few runs the springs lose their stiffness. To make more power your going to have to do it exactely the way you would with the chev motor, it's the only way your going to see an increase in usable power from the motor. As much compression as you can get and the biggest bang. If the engine can pull in more fuel at higher rpms, it doesn't matter how much if it isn't under enough pressure to make a more powerful downward stroke. Dale states that with 104 to 105 lc the engine will have a good broad powerband.You dont happen to have anymore details on those crazy lobe centers, do you? Or maybe a contact?
- coopstream
- coopstream
- chris41
B2, A3-A4 cams into KZ's these are a really good cam and should be reasonably cheap and easy to find, Try them at 106-106 stock for these cams is 105 - 108
- Old Man Rock
- Thank you received: 225
You might want to read through this to give yourself a better idea of what your facing pre buying any parts....
kzrider.com/index.php?option=com_docman&...d&gid=451&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- enaz1
75 z1 900 Big Guy
