Quick oil seal question...
- KawasakiBob
25 Mar 2006 11:31
I need to replace the clutch pushrod seal in my 82 1000J.
Someone mentioned that I need to split the cases to do this, is this true?
If not is there a trick to getting the new seal in properly?
I'm a grade Z mech so forgive my noobie-ish questions.
- xr350guy
Re: Quick oil seal question...
25 Mar 2006 12:26
clutch pushrod......is that the shaft that your cable is attached to?
- KawasakiBob
25 Mar 2006 12:35
No, the actual clutch push rod that can be pulled in or out if you have the left side cover off exposing the countershaft sprocket.
The rod can be pulled out or pushed in but the seal around it is pretty trashed, and is (one of) the sources for my oil leaks.
- twowheeledterror
25 Mar 2006 14:15
I wouldn't think you should need to crack the case apart to do this job. Maybe someone with specific info on your bike will know though?
- Duck
- e vica na i sau na ga
25 Mar 2006 14:36
That's not a bug.
It's a feature!
It's your automatic chain oiler!
-Duck
It's a feature!
-Duck
- btchalice
25 Mar 2006 15:03
im not sure about the 1000 but i did one on a 400 that was held in with a snap ring
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- KawasakiBob
25 Mar 2006 15:10
Duck wrote:
LMAO No I call it my James Bond Bike....leaving the oil slick behind me.
Cool but ty, I'll take a closer look in the morning and see if there is a snap ring.
That's not a bug.
It's a feature!
-Duck
