low compression
- TattooMark
02 Jan 2010 23:16 #341672
by TattooMark
low compression was created by TattooMark
Hello All... I have an 81 kz750 and i have low compression!! I am in the process of taking the motor out... anyone have any suggestions on what I need to look for first and if anyone else has had this problem? Thanks
- Nebr_Rex
- Thank you received: 300
03 Jan 2010 03:57 #341676
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic low compression
Is it rings or valves?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- mark1122
- Keep twisting it
- Thank you received: 109
03 Jan 2010 04:20 #341678
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic low compression
re-do the compresion test.remember to hold the throttle wide open when doing the test.
do it once dry, and once with a bit of oil in the cyl. the oil will seal the rings. if the compresion comes up, its the rings. if it stays low, its still leaking by the valves. check the valve clearance.
a leak down test is also helpful, but if the rings leak bad , its hard to hear any leakage at the valves.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
- Thank you received: 82
03 Jan 2010 06:07 #341685
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic low compression
mark1122 wrote:
+1
This is good advice. If you havn't already done the compression test this way, then repeat before you get that thing out.
+1
2004 ZX-10R
Angola, IN
- TattooMark
03 Jan 2010 09:25 #341693
by TattooMark
Replied by TattooMark on topic low compression
Thanks guys for the advice, I know what i will be doing this afternoon
