identify model...?
  • hammerguy09
  • hammerguy09's Avatar Topic Author
identify model...?
01 Jan 2010 23:02
#341545
can anyone help me identify the model of my bike. I believe it is a 78 kz1000
KZT00AE059583 KZT00B-08866
  • trianglelaguna
  • trianglelaguna's Avatar
Re: identify model...?
01 Jan 2010 23:15
#341547
i think her names bonita
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Jan 2010 02:36
#341549
Bonita is correct, but her numbers give us a bit more info. The motor VIN is the clearest of both...the engine started life as a 1978 KZ1000A2/B2/C1...Kawasaki used motors for all three models from the same motor production series (there is nothing inherent in the motor VIN that uniquely identifies which model it went into). The frame tells what model it is...however, you appear to be missing digits; the prefix KZT00B tells us it should have 12 total digits, not the 10 you gave. Zeros are important. The 'B' in the sixth place tells us it started life as a LTD, but you should have a number field of six rather than four numbers...if you don't have any more than four numbers, then you have an impossible frame number...this suggests several scenarios :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
02 Jan 2010 04:24
#341553
If it is an LTD, then the frame number would have a 5 at the front of the sequence number.
KZT00B-508866
All LTD's of that era where assembled in Lincoln NE, The white sticker on the steering head (if it's still there) would show it being assembled in the USA.
