- Thank you received: 76
Issues with APE web cam .410 grind anyone else?
- saxjonz
- KawboyZ
30 Dec 2009 13:29 #341220
by saxjonz
79 LTD B3
Issues with APE web cam .410 grind anyone else? was created by saxjonz
Upon taking the head down to replace a gasket I noticed on the intake cam number 4 that the tappet was pitted pretty badly. Looking closer at the cam itself I noticed pitting on the surface and when I looked at the edges of the grind I could see where little pieces of it had broken off. I looked at all of the other edges and they seemed like they were machined clean on the edges but this particular lobe looked like they may have forgotten to get the rough edges off.
The cam was purchased from APE so Jay maybe you have some feedback as to why? I will post pics of the cam and tappet when I am able to upload some decent pics of problem. :blink:
79 LTD B3
- Old Man Rock
- Thank you received: 225
30 Dec 2009 13:47 #341223
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Issues with APE web cam .410 grind anyone else?
Interesting... Here's why..
On my recent valve adjustments, found exhaust #1 would not hold to shim clearances during break in periods... Swap the shims and still would be under spec within 500 mile checks and measurements...
All of which led to "Ok, something just not right here"... Out with the tools for I had to know...
The image below shows pretty much the same as your describing where the cam bearings where pitted and the cam shaft under the bearings had worn down....
Head, off to Larry C for confirmations of possible damages to valves/seats ... New exhaust valves and OEM seals... Wet sand the bearings and shaft smooth, pre-lube, install & torque, re-shim ~ .15mm on exhaust, .10mm on intakes...
All better now, holding to spec after 500 miles on her ... Damn the man just does sweet ass work... Thanks Lar! Not to mention no smoke, even at start up! :woohoo:
Here's my WebCam .365 camshafts... Only happened under #1 exhaust cam. The arrows depict where the cam bearing grooved into the shaft... :ohmy:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
- Banned
- Thank you received: 58
30 Dec 2009 20:12 #341302
by APE Jay
Replied by APE Jay on topic Issues with APE web cam .410 grind anyone else?
Had not seen this, but if you are talking about the outer edge of the lobe, it would not hurt to break the edge with a belt sander. A lot of builders do this on new cams.
- BSKZ650
- Thank you received: 14
31 Dec 2009 05:43 #341344
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Issues with APE web cam .410 grind anyone else?
What you are describing sounds like the lifter is not turning, I have seen this on automotive cams.
it could be as simple as a small burr in the bucket area, take a sharpe pen and mark the edge of the bucket and rotate the engine it should move, if not look into why
- saxjonz
- KawboyZ
01 Jan 2010 07:46 - 01 Jan 2010 07:46 #341468
by saxjonz
79 LTD B3
Replied by saxjonz on topic Issues with APE web cam .410 grind anyone else?
A picture is worth a thousand words. Jay I think you said it best. The edge of the cam lobes that were hanging over because of the casting didn't have anything behind them to support them so they broke off and molested the tappet and lobe.
These pictures are, perhaps, worth 200 words each as they are a bit blurry but camera phones go figure.
79 LTD B3
Last edit: 01 Jan 2010 07:46 by saxjonz.
- saxjonz
- KawboyZ
01 Jan 2010 07:49 #341470
by saxjonz
79 LTD B3
This probably is not a big deal but I am a fan of precision and all parts operating at 100% and totally dialed in to be happy.
79 LTD B3
- saxjonz
- KawboyZ
01 Jan 2010 07:57 #341471
by saxjonz
79 LTD B3
So, Jay thanks. I think you hit it on the money. Kawbob that you now see the tappet you can see that it appears to be circulating judging by the pitting on it and Dave wow!, that looks like a groove but not one you feel like dancing to. I'll give you a call today to wish you a happy new year.
79 LTD B3
- APE Jay
- Banned
01 Jan 2010 11:43 #341496
by APE Jay
Good. At first I thought you might be having the same issue with them that others have had.... Bending the handlebars back :laugh:
- saxjonz
- KawboyZ
01 Jan 2010 12:21 - 01 Jan 2010 12:21 #341504
by saxjonz
79 LTD B3
Just because others drop a load when they twist the throttle doesn't mean that the bikes are too fast just means that they need to stop putting armorall on their iron board seats and stop buying their bars from the bargain bin at Warshawsky's.
79 LTD B3
Last edit: 01 Jan 2010 12:21 by saxjonz. Reason: spelling
