what about my exhaust
- squints
24 Mar 2006 20:20
I have a 1982 kz1000 CSR. Are my exhaust pipes a 1.5" size? I want slip ons that will fit 1 1/2" to 1 3/4" pipes - will this work?
And... how easy of a job is attacing slip ons? Is rejetting neccesary?
I know that sometimes re-jetting is a neccesity. What is rejetting? I dont know? It is one of those things I'd like to know what it is and if I can do it myself if need be.
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
Upstate NY
- squints
Re: what about my exhaust
27 Mar 2006 05:28
hello? anybody? Whats the diameter of my header pipes? 1982 kz1000m
little help over here?
I just want to double check it with you guys before I start taking things apart.
Upstate NY
Upstate NY
- rstnick
27 Mar 2006 06:00
I don't know the size of your header. Give it a guick measure.
Jetting is refering to the size of jets in the carbs. They control the amount of fuel that mixes with the air. When you make air filter and exhaust changes, you will need to rejet the carbs to ballance the changes. Adding air filters, like pods allow much more air in, so you will need to let more gas through with bigger jets. To rejet, you will have to remove the carbs and diassemble them. Find the right size new jets, plus you will have to readjust the air screws as well. It can be a tricky job to have set up just right.
In your case, just adding slip ons, you may not need any changes to the jetting on the carbs.
Do a search through the archives, lots of info on jetting in there.
Post edited by: rstnick, at: 2006/03/27 09:04
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- squints
27 Mar 2006 20:14
well, my the headers are 1.5 inches. Does that mean they're that wide at the other end? They dont taper out any?
Upstate NY
Upstate NY
