Stuck Block
- kawasakibikefan
- Riding is a passion most do not understand.
Is there any useful hints on how to get it unstuck?
'75 Z1B
'95 KLR250
My Future Buying List:
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- PLUMMEN
- Thank you received: 104
- kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- trianglelaguna
- Thank you received: 235
craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- bountyhunter
- Thank you received: 337
- kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- testarossa
- Thank you received: 82
the gasket is acting like a glue or caulk in my opinion and slow circles of tapping with a rubber mallt on the outer -lower edges will get it to come loose enough to tap some soft wood shims in and break the whole cylinder up and free...good luck
craig
+1
This is excellent advice. Continue to strike with the rubber mallet all the way around the jugs. It may not seem like there is anything happening, but those little hits add up. Sooner or later you'll hear the sound of the hits starting to change. It will come loose shortly after that. Just did this about three days ago on my 1000.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- BohicaBob
- Thank you received: 35
I bolt this bar onto the top of the block and use a big rubber/plastic mallet on each bar end alternately, firmly but gently hammering because you don't want to ruin those two 6-mm thread wholes. Ensure that you firmly bolt down the bar onto the block of course.
This tool has always worked for me no matter how sticky the cylinder base gasket is.
- kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
