will kz1000 police exhaust fit kz1000
- motom
28 Dec 2009 21:00 #341020
by motom
will kz1000 police exhaust fit kz1000 was created by motom
Will a kawasaki police exhaust system bolt right on to a 1977 KZ1000? It is a 2 into one like the stock originals.
- MFolks
- Thank you received: 540
28 Dec 2009 21:39 #341024
by MFolks
Replied by MFolks on topic will kz1000 police exhaust fit kz1000
It should bolt up with no problem, but measure the exhaust centers to be sure. Don't forget new exhaust gaskets(I think Z1 enterprises sells Kawasaki and the thicker Suzuki gaskets).
- Bluemeanie
- Thank you received: 14
29 Dec 2009 06:07 #341038
by Bluemeanie
Replied by Bluemeanie on topic will kz1000 police exhaust fit kz1000
Don't the 1000P's mufflers go straight back lower to clear the side trunks as opposed to the slightly upswept KZ1000 mufflers?
- Nebr_Rex
- Thank you received: 300
29 Dec 2009 07:22 #341056
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic will kz1000 police exhaust fit kz1000
Bluemeanie wrote:
Yes they are,The KZ1000st uses the same exhaust.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- motom
29 Dec 2009 10:50 #341086
by motom
Replied by motom on topic will kz1000 police exhaust fit kz1000
Trying to find an alternative to an expensive replacement exhaust.
i was noticing the mufflers on older Kawa police bikes. hoping that they would work and look right. Although hearing that they sit lower to accommodate police side cases, may not look right.
Looking at Bikebandit. They show that i can still get the original replacement exhaust for my 1977 kz1000. But there seems to be alot of bits and pieces. it will be expensive.
Also noticed z power online (located in Australia) and they offer a fine replacement exhaust, (pricey with shipping). Anyone try these? they are stock configured two into One on either side.
