Time-serts for cam cap bolts
- Buda
Any help would be appreciated.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Martynbiker
- 1993 KZ1000P
I agree with Nebr_Rex...I also just set mine deeper for the dowel holes. As an aside, if you are replacing helicoils that pulled out, you'll have to use Big-serts instead of Time-serts. If the threads are stripped for the first time, then use Time-serts.
What he just said.
Helicoils are the work of the DEVIL and must NEVER be used on anything you own. Timeserts and Bigserts are the way to go!!!!!!!:woohoo:
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
- Buda
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Mcdroid
- Gone Kwackers
Note that the J motors are notorious for stripping cam cap bolts. Interestingly, we have been discussing this same issue on www.kz1000r.com and as was pointed out by a member (from the Z1 Owners Group (UK)) it is likely the cam cap torque specs for the J motors are incorrect in all the manuals. The torque specs are listed as 12 ftlbs...this exceeds the torque specs for a automotive-grade M6 bolt. The torque for a J motor cam cap bolt should be between 8 and 9.5 ftlbs...the UK folks have been doing this for quite some time and the cam cap stripping has more or less stopped.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Buda
those bolt and found the same thing. I used 92in/lbs on the rest and had no more problems.
Again I appreciate your help.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Mcdroid
- Gone Kwackers
...can anyone recomend a source for the kits needed to redo a j cam capthat is on it's first striping......am i wrong that i can feel a hand held small ratchet as it is getting goodntite...i think that's how i tightened 20 yrs ago...never had problems back then...???
Try this guy...communicates well and ships very fast. I have purchased a number of times from him.
www.toolsqwik.com/storefrontprofiles/default.aspx?sfid=158898
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- RonKZ650
- Thank you received: 240
Maybe it's luck, maybe sometimes the helicoil is installed wrong sometimes, I don't know, but they work just fine. You'll never strip a helicoil as it's stainless steel. Also 12ft/lb is way too much for any 6mm bolt. I don't care what the manuals say, you'll strip them all at 12ft/lb. Isn't it like 5.5ft/lb on your basic 6mm bolt otherwise? I stay there and they will strip at 5.5 even sometimes. Oops I forget, don't use ft/lb, tighten to 66in/lb. Much better.
- 9am53
that's where I got mine, they were quick as the name says, and they didn't cost much either,m and they shipped to canada for cheap too.
'84 GPz900r
'71 CB350
