Time-serts for cam cap bolts
  • Buda
  • Buda's Avatar Topic Author
28 Dec 2009 20:30
#341014
I think I need m6x1.0 lenght 9.4mm is it the right size? Will the time-sert fit under the dowel?
Any help would be appreciated.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Time-serts for cam cap bolts
28 Dec 2009 20:38
#341015
Yes,you'll have to run it down deeper than the other.I did it on my ST.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Dec 2009 02:47
#341032
I agree with Nebr_Rex...I also just set mine deeper for the dowel holes. As an aside, if you are replacing helicoils that pulled out, you'll have to use Big-serts instead of Time-serts. If the threads are stripped for the first time, then use Time-serts.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Martynbiker
  • Martynbiker's Avatar
  • 1993 KZ1000P
29 Dec 2009 03:57
#341033
What he just said.
Helicoils are the work of the DEVIL and must NEVER be used on anything you own. Timeserts and Bigserts are the way to go!!!!!!!:woohoo:
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
  • Buda
29 Dec 2009 08:51 - 29 Dec 2009 08:54
#341073
I got 2 holes that I taped up to the next size M7x1.0 will the big-serts work for those?
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 29 Dec 2009 08:54 by Buda.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Dec 2009 09:47
#341075
If you measured the hole size at 7.0 mm, then it is too big for the 6X1.0 time-sert...next would then be the Big-sert...you need to buy the kit (which has the drill, countersink, tap, insert tool, and 5 Big-serts). However, you have to be careful with Big-serts as they are very difficult to remove (if you screw up) as they have a camlocking mechanism...whereas the Time-serts do not and can be removed with an easy-out (which almost never work either :laugh: by the way). It will take some planning and measuring to ensure that you are setting your inserts deep enough.
Note that the J motors are notorious for stripping cam cap bolts. Interestingly, we have been discussing this same issue on www.kz1000r.com and as was pointed out by a member (from the Z1 Owners Group (UK)) it is likely the cam cap torque specs for the J motors are incorrect in all the manuals. The torque specs are listed as 12 ftlbs...this exceeds the torque specs for a automotive-grade M6 bolt. The torque for a J motor cam cap bolt should be between 8 and 9.5 ftlbs...the UK folks have been doing this for quite some time and the cam cap stripping has more or less stopped.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Buda
29 Dec 2009 10:02
#341081
Thanks after I stripped 2 holes I looked into the torque for
those bolt and found the same thing. I used 92in/lbs on the rest and had no more problems.
Again I appreciate your help.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • trianglelaguna
  • trianglelaguna's Avatar
29 Dec 2009 12:37
#341102
...can anyone recomend a source for the kits needed to redo a j cam capthat is on it's first striping......am i wrong that i can feel a hand held small ratchet as it is getting goodntite...i think that's how i tightened 20 yrs ago...never had problems back then...???
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
29 Dec 2009 12:49
#341105
Hey buda, I tightened my J head cam cap bolts to 12 foot pounds and broke a bolt and stripped 2 holes about 2 weeks ago...just got my helicoil set in the mail today. I will be putting them in tonight. Somewhere on here I saw someone say that helicoils are fine, if they strip out then you can put in time serts, I figure start small, the helicoils cost very little, and if they don't work out then no hair off my back.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Dec 2009 13:13
#341106
Try this guy...communicates well and ships very fast. I have purchased a number of times from him.
www.toolsqwik.com/storefrontprofiles/default.aspx?sfid=158898
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • RonKZ650
  • RonKZ650's Avatar
29 Dec 2009 13:17
#341110
Just for the record, over the years I've personally done 50 or more helicoil repairs. everything from spark plugs to 6mm bolts to 1/2" bolts and let me count all these problems I've had----Zero
Maybe it's luck, maybe sometimes the helicoil is installed wrong sometimes, I don't know, but they work just fine. You'll never strip a helicoil as it's stainless steel. Also 12ft/lb is way too much for any 6mm bolt. I don't care what the manuals say, you'll strip them all at 12ft/lb. Isn't it like 5.5ft/lb on your basic 6mm bolt otherwise? I stay there and they will strip at 5.5 even sometimes. Oops I forget, don't use ft/lb, tighten to 66in/lb. Much better.:)
  • 9am53
  • 9am53's Avatar
29 Dec 2009 13:19
#341111
that's where I got mine, they were quick as the name says, and they didn't cost much either,m and they shipped to canada for cheap too.
