Flex-hone size?
- KZ1100 Bully
27 Dec 2009 15:59 #340868
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
Flex-hone size? was created by KZ1100 Bully
Hi, I bought a set of rings and now need to hone the cylinders. Not sure what size flex hone to buy. Anybody know what size and grit to use on a 1983 kz1100 D2 Spectre?
Thanks
Thanks
- davel
27 Dec 2009 21:44 #340902
by davel
Replied by davel on topic Flex-hone size?
Wiseco recommends a 280 grit finish hone.
- Nebr_Rex
- Thank you received: 300
28 Dec 2009 04:19 #340910
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Flex-hone size?
I reccomend not useing a flex hone.If you use an inexpensive ajustable hone you can get at the auto parts store you will get a better ring seal than with a flex hone. The cylinder walls will be straighter.You will be able to see your high and low spots during the maching process.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Old Man Rock
- Thank you received: 225
28 Dec 2009 06:39 #340930
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Flex-hone size?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KZ1100 Bully
28 Dec 2009 06:53 #340932
by KZ1100 Bully
Replied by KZ1100 Bully on topic Flex-hone size?
Ok thanks guys. I will get the adjustable one.
Do you go up and down in a pretty fast motion for about 7 seconds than reverse the drill and do it again for another 7 seconds.
Motor oil be okay to lube?
- Nebr_Rex
28 Dec 2009 07:02 #340933
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
KZ1100 Bully wrote:
move up and down in same direction to get the correct crosshatch,motor oil is fine,the thicker the oil the less the cutting action of the stone for a given pressure of the hone,I have even used solvent to get a deeper cut
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Old Man Rock
28 Dec 2009 07:17 #340936
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KZ1100 Bully
28 Dec 2009 07:47 #340937
by KZ1100 Bully
Great, that's what I needed to know.
Thanks
Thanks
