- Thank you received: 6
Clutch plate question
- fordtruck
27 Dec 2009 15:18 #340862
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Clutch plate question was created by fordtruck
In the next couple of weeks I will be tearing down the motor on my 77 KZ1000 to rebuild it with a 1075 kit. While I have it apart I plan on pulling the clutch and inspecting it. It's not slipping now, but I'm going to measure the friction discs to see if they are within spec. I've read about people sandblasting the metal plates to knock off the glaze. I don't have access to a sandblaster, so what is the next best thing to use on them?
- keith1
- Thank you received: 2
27 Dec 2009 15:44 #340865
by keith1
Replied by keith1 on topic Clutch plate question
i would venture a high count sand paper or a 3m scotchbrite.....if you plan on keeping bike , i would get new fibers and metals and be done with it.....i think i am going to go with the 4/4 redline offers....4 stock fibers and 4 barnetts.....i have had barnetts before and they hold like a sombitch although a little less than smooth compared to stock as far as engagement......i have all new metals and fibres that have 1k on em, but i get a little bit of slippage during the first couple of launches into the ride....after that all is well.....on my gs1150 it was the clutch hub.....gotta peek around in there.......just my .02.....
- Old Man Rock
- Thank you received: 225
27 Dec 2009 15:58 #340867
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Clutch plate question
Advice provided to me... stay with OEM plates and springs... ~ $120 for friction & steel plates and springs
I'm now using Synthetic oil, no issues what so ever....
OMR
In case you need it.... For the KZ900 but should be close or exactly the same....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2829
27 Dec 2009 16:32 #340870
by 650ed
Replied by 650ed on topic Clutch plate question
OMR wrote: "Advice provided to me... stay with OEM plates and springs... ~ $120 for friction & steel plates and springs
I'm now using Synthetic oil, no issues what so ever..."
Ditto here. Ed
Ditto here. Ed
- racer54
- Thank you received: 114
29 Dec 2009 17:27 #341138
by racer54
Replied by racer54 on topic Clutch plate question
For years I have taken clutch apart and after wiping off the oil and drying, I take emery cloth to the steels to get glase off. Usually shows sanding marks depending on roughness of paper. Use finer paper. I also use emery cloth on the fibers til they get a dull look which is taking the glaze off. Had bike slip clutch really bad and after doing this, hooked like a bitch! Doesn't really take alot of work but really makes the clutch work better. This isn't rocket science here. Just wipe them off, de-glaze them and re-install. Pay attention how they come out as the steels have a sharp edge on one side and a rounded side. Can't remember right now which side goes in first though, but it does make a difference over time. Will work either way but the correct way is better as the sharp edge doesn't slide as easy as the rounded edge. Some guys will put in heavier springs for a slipping clutch but unless you are pushing massive amounts of HP, you shouldn't need them. Re-doing the clutch like above eliminates lots of the problems.
- fordtruck
29 Dec 2009 22:12 #341156
by fordtruck
Replied by fordtruck on topic Clutch plate question
Thanks guys!
