engine problem?
- jizzle123
26 Dec 2009 20:24 #340785
by jizzle123
engine problem? was created by jizzle123
Hey everyone this is my first post i've browsed the forums for awhile though.
I ride a 1980 kz650 i recently bought, its my first bike and ive had a problem. when i ride the bike its been cutting off sometimes itll run good but if i give it gas too quickly itll just cut off and as of tonight when i ride itll randomly wine down and just kind of sputter till it cuts off even if i have the choke on. it seems to be getting worse to i had the bike cut off on me 4 times on my way home in my neighborhood. what could the problem be?:S
- MFolks
- Thank you received: 540
26 Dec 2009 20:41 #340787
by MFolks
Replied by MFolks on topic engine problem?
Several things to check:
1.Fully charged battery.
2.All related battery connections must be clean and tight,especially the Black, Negative(-) terminal to the engine as this is the ground connection
3.Properly gapped and corect heat range sparkplugs(most bikes Kawasaki made in this time period used NGK B8ES sparkplugs gapped between 0.028" to 0.032")
4.Drop the carb float bowls and check for sediment/crud/water in the gas.
5.Check the valve clearances as on this type of engine as the valves wear,they make the engine less and less noisey, In other words, a little valve clatter is good, when it stops, burning valves may result.
6.Clean/replace the airfiters.
7.Do a compression check, as I think 125 PSI is what you need,any lower than that and the engine may not run good.
8.If possible replace the sparkplug wires from the ignition coils to the sparkplugs and the sparkplug caps as both age and can fail/become intermittent.
Just some ideas.....................
- PLUMMEN
- Thank you received: 104
26 Dec 2009 21:06 #340788
by PLUMMEN
Replied by PLUMMEN on topic engine problem?
getting gas?
- Old Man Rock
- Thank you received: 225
27 Dec 2009 06:52 #340813
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic engine problem?
Was thinking the same here...
Gas/clogged fuel filter/Carbs or Ignition electrical issues such as coils/coil voltage/points/condenser/EI etc...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Martynbiker
- 1993 KZ1000P
27 Dec 2009 15:32 #340864
by Martynbiker
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
Replied by Martynbiker on topic engine problem?
sounds like there may be water in the fuel. I had a similar prob with a CB750.... drove me nuts till i drained the tank and seafoamed it.
but... ask 1000 Bikers the same question and you will get a whole bunch of different answers! Intermittent problems are a PITA~
- Vter Bob
- Thank you received: 4
27 Dec 2009 16:41 #340871
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
Replied by Vter Bob on topic engine problem?
Have you checked the vent hole in the tank to see if it's blocked?
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
