- Thank you received: 38
Putting it all back together.
- sbc1320
01 Jan 2010 06:42 #341462
by sbc1320
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic Putting it all back together.
My oil rings were the 3 piece which are a lot easier than the one piece oil ring. I do have Snap On ring compressors for my car engines of which I have done a lot of. On car engines I know the Snap On type is much easier than the regular cheapy ring compressor. The idea of using a a zip tie (big fat one) makes good sense. Anyways mine is done, and is the first 4 cylinder bike I have done. Last car engine I did I hammered on it for 5 years on the strip and street running 11:60's on motor. Man I miss my old 71 Nova.
- mark1122
- Keep twisting it
- Thank you received: 109
02 Jan 2010 12:21 - 04 Jan 2010 06:07 #341594
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Putting it all back together.
i've seen the piston with rings , inserted into the barrels then slide the barrels on and insert pins and clips (buttons are even easier). the guy put the motor on end, so he could slide the barrels on, from and upward angle.:side:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 04 Jan 2010 06:07 by mark1122.
- School Teacher
03 Jan 2010 22:19 #341764
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic Putting it all back together.
the biggest thing is get a friend to help, four hands around the rings is cake and cuts the time by 3/4, tap tap tappy with th palm of your hand it will go. I always do 2and 3 first so one and 4 are not in your way for 2 and 3.
1980 kz1000G1
- TerryK
04 Jan 2010 17:40 #341818
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Putting it all back together.
I wouldn't advise doing this if you haven't before, or at least seen it done before. Get just one ring wrong and you've got trouble.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- cricketfire46
11 Jan 2010 19:48 #342635
by cricketfire46
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
Replied by cricketfire46 on topic Putting it all back together.
found out that pulling the pistons off the crank shaft was super easy. Since I have done this on a car before I decided this was the way to go. Still haven't gotten it all back together thanks to cold weather and no heater in the shop. Really sucks because we don't know how to deal with 19 degrees in TX. Should be doing it all sometime next week.
- 9am53
- homebrew, and some bbq
12 Jan 2010 04:51 #342648
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic Putting it all back together.
Hey noob! Here is my noob friendly thread. On page 6 I show my wooden forks that I used to hold up pistons 2 and 3 while I put the cylinders down.
kzrider.com/index.php?option=com_kunena&...it=20&limitstart=100
If this is your first time, unlike other things for your first time, it will take a while, so don't weat it. You will likely be doing the same thing over and over, but you will get it.
'84 GPz900r
'71 CB350
- Kawickrice
- Thank you received: 18
12 Jan 2010 04:59 #342649
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Putting it all back together.
9am53 wrote:
HAHAHA :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
