Set screw on right side
  • cricketfire46
  • cricketfire46's Avatar Topic Author
22 Dec 2009 08:46
#340267
In true TX style I will do my best to describe this part, but will get a pic up tomorrow. On the right hand side of the motor, on the shaft where there is a #12 head and a #17 bolt head there is a set screw. Somehow in attempting to reset cam timing after pulling cams off I managed to booger up the little allen head set screw that was on the outside of the #17 bolt head. Can anyone tell me what size this little screw is so I can attempt to remove it without using an EZ-out, and replace it.
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Set screw on right side
22 Dec 2009 13:01
#340292
Not sure exactly where your describing, but if it's part #220 in the diagram below, one of the three screws that hold the ignition pick up plate, they are a size 5x12 mm.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • cricketfire46
22 Dec 2009 13:44
#340300
if I looked at the diagram right, I believe the set screw is on the outside of part 21148. It is a small allen head screw that I flattened out, It kept the 17mm nut with the split on it from free spinning
  • RonKZ650
  • RonKZ650's Avatar
22 Dec 2009 14:27
#340301
It sounds like someone's done some "creative engineering" possibly. Normally the #21148 has tabs that keep the nut # 92022 from spinning, then bolt # 92001 holds the unit to the crankshaft. So when you turn the engine over use the 17mm, it turns the advancer by the tabs engaged in it. I've never seen an allen setup.
  • MFolks
  • MFolks's Avatar
22 Dec 2009 15:04
#340303
Can you send a picture of this set screw? I'm curious too as to what the previous owner(s) did.
  • cricketfire46
25 Dec 2009 11:26
#340658
Wasnt a set screw, just a keeper pin. Got it out and getting a new one now
