The elusive KZ550 transmission into a KZ650/750 tr
- kopcicle
Re: The elusive KZ550 transmission into a KZ650/750 tr
09 Jul 2012 15:25
Split the cases
~kop
~kop
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
- 750steve
09 Jul 2012 19:09 - 09 Jul 2012 19:10
Okay!! But the GPz motor don't sound too good so i passed!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 09 Jul 2012 19:10 by 750steve.
- RTGPZ
02 Dec 2012 07:40
I used the shift forks and drum from 550, the gear select for your foot is a750, the neutral safety switch plate on the end of drum has to be repositioned for 750 cover , your offset for sprocket will be around 7/8 of an inch for a six inch rim_ you can aquire one from d&g chassis in florida, I used a750 clutch and had to thin down the washer to get enough room for nut to thread on. Be careful things get tight dont take to much.
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
Reinforced frame
- RTGPZ
02 Dec 2012 07:53
On the end of the transmission output shaft for sprocket you have to choose between the lesser of two evils, drilling a hole to bolt sprocket on or welding a 3/4 fine thread spud on end of output shaft. I welded a spud but I'm a cert welder and machinist.trans is still doing fine on my bike. I also built my own bearing support under the sprocket cover so to not wear out trans bearings
Reinforced frame
Reinforced frame
- 750steve
05 Dec 2012 21:29
Guys, hope someone sees this.....what year/model of ZX6/ZX600/ZZR600 gearbox works in this conversion?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
