The elusive KZ550 transmission into a KZ650/750 tr
- rstnick
Re: The elusive KZ550 transmission into a KZ650/750 tr
20 May 2010 12:01
Ilja wrote:
That is a very nice 650 there Ilja.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- steell
21 May 2010 08:02
A few things about the 550>750 six speed swap.
Need to use an offset sprocket or just prefer the nut type lock?
Use the Shaft drive six speed trans (or at least the output shaft), the splines for the shaft coupler are the same as the sprocket splines.
I tried to install the gears off the six speed onto the GPz trans also, but the splines were different.
Kool-Aid kid ran into other problems and got distracted with other projects, he just got started on his GPz again.
I almost got distracted with a Turbo motor and a spare Turbo frame, but I'm back on track with my 80 750E hot rod project
Bummer, no more cheap shaft drive six speed 550 trans after people read this
- seanof30306
21 May 2010 08:16
Steell,
I believe it was Mark Wing who tried this swap in a kickstart engine. Everything worked when it was loosely bolted together, but he had problems when it was all torqued down. I think it wouldn't go into 6th, if memory serves me.
That makes me think the tolerances must be pretty close. Having done this swap, do you think something could be machined a bit to make this work?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- hardr0ck68
- Who put the what in the where?
21 May 2010 12:47
thanks for the shafty tip!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- Ilja
21 May 2010 14:14
steell wrote:
Thank you so much!!
I have a shaft kz550 engine lying around in the shed. I didn't think it would fit so I bought a normal Kz550 trans... But with that one I will have the offset problem with the front sprocket because of my zephyr engine..
I'm going to do the trans swap after this season as I just finished my bike and I need it for transport right now. (100km a day :side: ) But I can't wait to do it! Maybe I'll do it sooner, but I'm afraid I will open the Can-o-worms.. :silly:
Thanks again for the information!
Thank you so much!!
I have a shaft kz550 engine lying around in the shed. I didn't think it would fit so I bought a normal Kz550 trans... But with that one I will have the offset problem with the front sprocket because of my zephyr engine..I'm going to do the trans swap after this season as I just finished my bike and I need it for transport right now. (100km a day :side: ) But I can't wait to do it! Maybe I'll do it sooner, but I'm afraid I will open the Can-o-worms.. :silly:
- GPzephyr
22 May 2010 00:22 - 22 May 2010 00:23
When I did mine I didn't have a problem with sprocket offset, but that said it shouldn't be too difficult to sort that out.
Incidently the 2000-02 ZX6R uses a front sprocket with an offset of about 7mm but... its only available in 15 tooth and its not dished so it might be too thick for the 550 fixing method.
I'm currently using one of these on my Turbo to give me the offset I require for my VFR rear swingarm.
It might be worth finding a friendly dealer who can lend you one to quickly check.
Oh and if its any help you can find sprockets from all sorts of bikes can fit. I found that the Suzuki Hyabusa rear sprocket is an identical fit to my Zephyr rear wheel for instance and was using one when I switched to the Turbo engine.
The front sprocket gearbox splines are the same for virtually all Kwacks up to 750cc its just the fitting method that seems to vary.
That bike of yours looks very sweet llja
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
Last edit: 22 May 2010 00:23 by GPzephyr.
- Ilja
30 Dec 2010 12:01
Ok guys, im am planning on doing the six speed conversion on my kz650 zephyr the next couple of days/ weeks.
I have a complete engine of a kz550 shaft version and the trans of a normal kz550 for parts.
Disassembled the kz550 'shaft' engine today and found out that it won't fit. At least the output shaft won't. It's waaay shorter than a normal output shaft. I don't think it would even stick out of the normal transmission cover.. :dry:
So the only way i'm going to have succes doing this mod is to use the normal trans with the 'wacky washer fitting method.'
The problem is my chain alignment. The front sprocket on a zephyr 750 engine is placed about 10mm more outward then the kz550/650 front sprocket. I need this offset because i'm running a 160 rear tire.
So I would need an offset sprocket with the washer fitting method to make it work. Does anyone know where I can get these?
- steell
31 Dec 2010 08:57
I was mistaken about the shaft drive trans working, it seems someone swapped some parts between the boxes that contained the two transmissions, leading to my confusion :blush:
Think maybe you could use a snap ring to hold the sprocket on? That would enable the use of an offset sprocket on the 550 shaft I would think.
- Ilja
31 Dec 2010 09:21 - 31 Dec 2010 09:22
Yeah, I think a circlip will be fine. I can probably even make the washer fit.
I will need 13mm of offset. Right now I have a (new)525 chain as the zephyr engine and my rear cbr wheel stock have 525 sprockets and chains... That's a pity because all offset sprockets are 530... O well... I'll just machine 1.5mm of the sprocket so it becomes 525...
When my chain and rear sprocket wear out i'll go 530.
It would seem to me that offset sprockets wear quicker, (and also the shaft) because they want to pivot as the chain pulls out of the middle....but not shure.
The engine will also be turbocharged, so hope it will hold..
Last edit: 31 Dec 2010 09:22 by Ilja.
- RTGPZ
26 Nov 2011 21:03
relocating the neutral safety switch plate on drum will allow 750 trans cover to be used. All you have to do is take plate off end of drum move taller pin to the neutral safety switch location in relation to 750 trans cover. :laugh:
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
Reinforced frame
- joat2002
10 Mar 2012 17:30
Planing on doing this to my kz650 but was wondering if I can keep the primary from the 650 on the 550 trans
- 750steve
07 Jul 2012 15:11 - 07 Jul 2012 15:13
Nice write up guys! Im looking at a 83 GPz750 motor to put into my Z650, there is one locally but the transmission is making a noise so instead of buying new parts to fix it i'd be better off doing this, especially as i plan to go 810cc.
So, just to recap;
1/The KZ550, Zephyr 550 (ZR550) & ZX600 (what year for us europeans?, we called them ZX6's) all have a 6 speed tranny & they will fit.
2/Do the gear selectors need to be moved over too? (&what else)
3/The GPz case can be used if the neutral switch plate is repositioned?
4/I'm going to need an offset front sprocket anyway as i'll be running a wider rear rim but does this swap mean that i'll need more offset?
5/ Any complications in refitting the GPz clutch?
Is there anything more an pure amateur needs to know? like this>
If the engine is out, tilted so you're looking at the bottom of the transmission & the oil pan removed is this swap possible?
So, just to recap;
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 07 Jul 2012 15:13 by 750steve.
