Valve clearance
- rayellis
I checked valve clearance today did not quite make specs. 3 of the valves are .07mm clearance and not in spec range of .08mm to .18mm. I have had low compression problems and this was one things I have not checked.
Should I go ahead and change the shims? Is it possible to move some shims around so to make all valves in line with specs?
Thanks
Ray:woohoo:
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- rayellis
I have tried everything that I can to fix short of complete tear down. I need to try another compression test but if I have low compression I might just pull top end and take a look.The numbers below is what I remember.
cyl 1 120psi
cyl 2 115psi
cyl 3 45psi
cyl 4 90psi
Thanks
Ray
- Jeff.Saunders
Usually with a bent valve, you have valve clearance extremely wide (as the valve is not returning fully.
I've never had that low a compression with worn rings, so you may want to go back through and verify the numbers. If you have a leakdown tester, they help tremendously in isolating the issue.
www.z1enterprises.com
Z1 Ent on Facebook,
- timebomb33
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Re-Build the top end
You will re-LOVE your bike! :laugh:
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
Which bike is this for?
Spec on KZ900 for sure, 1000 I think is .05-.10mm....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- rayellis
- TeK9iNe
".08mm to .18mm"....
My 1000 is .05 - .15mm
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- rayellis
Thanks
Ray
- chiefgto
- War was just a game we played when we were kids.
1979 LTD1000 B3 Chassis.
1980 LTD1000 Engine.
MTC 1075 10.5-1 pistons, 3 angle valve job with mild port and polish. V&H 4 into 1 pipe. Mikuni BS34 Carbs. Dyna 2000 ignition.
- bill_wilcox100
- Thank you received: 5
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
