Why are guys so down on FRAM oil filters?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Why are guys so down on FRAM oil filters?
26 Dec 2009 20:06
#340784
austin3119 wrote:
Fram Blowwwwwwsssss. Just kidding. I haven't used them since about 1992. I have read that the Tough Guard series is good.
Actually, if you want to know about filters, here's the place to go. Over 6000 threads worth of reading.
www.bobistheoilguy.com/forums/ubbthreads...tlist&Board=6&page=1
a guy could go cross eyed reading all of that! :laugh: good info though B)
  • dejavoodo41
  • dejavoodo41's Avatar
26 Dec 2009 20:39
#340786
My reasoning for using Emgo is that it is actually pretty difficult to find a filter here for my bike. I've ridden about 25,000 miles this year and change my oil about every 2000 miles I was using the Fram but Walmart stopped carrying them. I wanted K&N but Cycle Gear doesn't carry them for my bike and if the part stores have the filter they don't have the oil I want or vice versa so it is just more convenient for me to keep a couple of Emgo's on hand, buy my oil by the case and change my oil more often.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
26 Dec 2009 21:14 - 26 Dec 2009 21:14
#340789
Why not just order some K&N filters and have them on hand when you need them?
K&N for 1980 KZ1000A MKII
Last edit: 26 Dec 2009 21:14 by 650ed.
  • Old Man Rock
  • Old Man Rock's Avatar
27 Dec 2009 07:27
#340819
What about these... Anyone use them before?
cgi.ebay.com/ebaymotors/Kawasaki-Z1-KZ90...fPartsQ5fAccessories
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
27 Dec 2009 07:50
#340823
Just out of curiosity.... & Please don't get me wrong here for I'm all 4 paying a little extra for quality components... ;)
The KZ oil passage design incorporates several features such as oil filter bypass if clogged and an oil sensor switch if pressure is not within specification....
See image, 2nd paragraph.
With these features in mind, how did we blow up/seize an engine due to a Fram oil filters?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
27 Dec 2009 08:16
#340830
Old Man Rock wrote: "What about these... Anyone use them before?"
Interesting concept, but cleaning them sounds like a messy job. Seems like you would need to pressurize the inside of the filter with clean oil to "backflush" the screening material. But where and how you do that without making a mess is beyond me, and then you've contaminated and wasted the backflushing oil. If you used a solvent or hot soapy water to clean them you would need to somehow purge it all from the nooks and crannies of the filter or it would end up in your engine. They cost as much as a dozen K&N's; before I cleaned one of them a dozen times the novelty would have worn off and I would be back to using disposable filters (but that's just the way I am - lazy). I wonder if the filter comes with cleaning recommendations. Ed
  • Old Man Rock
27 Dec 2009 08:25
#340833
Have no idea, probably a solvent container, soak and then rinse I guess... Just came across them and considering this topic, figured I ask...
Personally, filter change every other 3K miles so I'll stick with the normal filters as well...
Wix brand filters, NAPA right... Do they come with the rubber drain plug & large filter plate O-rings?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Vter Bob
  • Vter Bob's Avatar
27 Dec 2009 10:26
#340842
OMR, both the Wix and Napa filters I have bought have included both o-rings.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
27 Dec 2009 13:49
#340853
Had a buddy buy a 08 cbr 1000 right off the showroom floor. We did he first oil change and used a fram motorcycle filter. Started it up, it was knocking.. knocking.. KNOCK..KNOCK..KNOCK.KNOCK. The top end was getting starved quickly, we took the fram off and got a new one. Yep, got a defective oil filter. Don't use Fram SHIT!
Heres a very good article regarding oil filters
motorcycleinfo.calsci.com/Filters.html#OilFilters
  • Old Man Rock
27 Dec 2009 14:41
#340859
Sweet for I just love having new O-rings each filter change....! Napa within 2 miles away from me home.... B)
Thanks for the update....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
