- Thank you received: 28
Sparkplug Indexing...
- TeK9iNe
- What did you do!?!
It's basically using very thin washers to ensure that the plug strap faces away from the center of the combustion chamber. The best position is with the plugs firing center (directly opposite the strap), to be facing about 10-15 degrees towards the exhaust valve.
This apparently directs the flamefront through the chamber better, and prevents "awkward" ignition from a strap accidentally facing directly center (which happens often).
Increases idle smoothness, and low end HP, nothing much at top end i think...
Anyone done this before? Results?
The kits are about $10, can't hurt.?.?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
- Thank you received: 337
Teams have been doing this in Top Fuel and many other motorsports for years, with dyno proven results...
I have not seen dyno tests on this done for a stock engine, but I will stick my nuts on the chopping block and predict that the difference is negligible (less than a couple of percent difference at most which is within measurement error range).
If you stand in a garage full of vaporized gasoline fumes and light up a cigarette, I do not believe the reaction that follows will change regardless of which way you are facing when you strike the match.
I could be wrong, but I would like to see some proof that indexing the electrode could have any measurable effect on a stock engine.
The reason I am skeptical is that seems to be similar to another scam going on about the new super duper spark plugs that "store" massive amounts of energy and then explode a huge spark. They published dyno tests and the difference was like .01%, which is less than the margin of error.
If there is free power to be had, I'd like to know but I am skeptical.
- bountyhunter
that's the part I don't get. The chamber is full of compressed (highly explosive) fuel and you are lighting it at the "edge" not the center. I don't really understand how having the electrode at various positions makes any difference since the flame front still has to proceed outward and across the combustion chamber from what is essentially a point source on the edge. I'll defer to experts, but I don't see it.This apparently directs the flamefront through the chamber better, and prevents "awkward" ignition
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- bountyhunter
I might believe on a 6000 HP drag engine some wierd things go on and benefit from such tweaking, I have trouble believing it could be seen on a stock engine. If it was true you could get a power gain from indexing, bike makers would be doing it for sure since it basically costs nothing to do.
- mark1122
- Keep twisting it
- Thank you received: 109
If u can feel a dif on a stock motor , u need a better ignition system.
Poor ignition was common in tne old bikes. easy to upgrade now.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
- TeK9iNe
As far as for small engines, they would have to be heavily modified (lots of idle lope), and even then it really only assists at low idle.
Really, you could do this for free if you wanted.
:laugh: whatever! Something else to try...
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- les holt
- Thank you received: 288
Just a thought
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- krazinite2003
i have two 1983 kz750 L3
