1980 KZ1000 LTD cam chain removal/replace
  • muddy1
  • muddy1's Avatar Topic Author
  • 1980 Kz1000 LTD B4
Re: 1980 KZ1000 LTD cam chain removal/replace
06 Dec 2009 11:46
#337780
I do not beleive that I am capable of removing the engine and splitting the cases to install a one piece cam chain, in fear of broken bolts chipped/cracked cases etc. :ohmy:
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • polkat
  • polkat's Avatar
06 Dec 2009 11:46
#337781
Old Man Rock, would that method of swapping the cam chain without splitting the case also work on the 750-4's?
  • PLUMMEN
  • PLUMMEN's Avatar
06 Dec 2009 11:49
#337783
yep B)
  • muddy1
06 Dec 2009 12:00
#337786
for the cam chain I could just rivet the chain back together instead of using a master link :lol:
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • timebomb33
  • timebomb33's Avatar
06 Dec 2009 12:55
#337795
if your worried about your skill level then don't attempt riviting the master it would be easier and you would have a much greater chance of success splitting the cases then putting that chain together use a one piece chain and sleep better at night do you have a manual. if you do they explain exactly how to split your cases. it is easy and really straight forward.
I THINK MY POWERBAND BROKE
  • keith1
  • keith1's Avatar
06 Dec 2009 14:49
#337819
muddy1 wrote:
No oring on the cylinder block, wonder why I would be sent a one piece copper gasket....any other head gasket options?
I would not think a oem style 72mm composite o ring gasket would hold up
the compression ratio is 10.5:1
joe must have a lot of those copper gaskets around..:laugh:
i sold mine on ebay and bought a cometic gasket...i think i got mine at redline....
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
06 Dec 2009 15:10
#337824
There is a lot of options thrown at you.
Just do what you think you are comfortable with.
I know a lot of riders here that use a link in thier timing chain. Roy
