Engine oil turns black 50 miles after oil change
- onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
- bountyhunter
- Thank you received: 338
Maybe so, but I recall I wnt to the MSDS sheets on both the redline stuff and ZDDPlus to calculate concentrations of zinc/phos and the ZDDPlus is WAYYY more concentrated. The redline recommends a certain dilution, but does not give anywhere near what ZDDP does because it's more concentrated.bountyhunter wrote:
This is correct, Zinc and Sulfur, which are necessary for our engines are bring removed. The problem with ZDDPluss is that it more than doubles the price of the oil. For $8+ a bottle which treats 5qts. it is outrageous. I use Red Line Additive which costs $12 and treats 16+ Quarts. If you use Rotella-T you do not have to worry about it at all. Rotella has the Zinc and Sulfur and I pay about $8 at Wall-mart for it. I bought ZDDPluss once and it was a ripoff. If you want to use an additive use the Red-Line.onanysunday wrote:
The problem is most name brand oils are eliminating zinc and phos additives and any flat tappet engine really needs them. I add a some ZDDPlus to mine to be safe.I like the 15w-45 viscosity of Rotella. I buy the 4 qt. jugs for about $9. I thought of using even cheaper car oils but I thought smaller motorcycle engines had different additive package requirements-something about different Ash or Zinc requirements than car engines? Is that true?
Exactly how much you need is another question, but I believe the ZDDPlus added as prescribed increases the zinc/phos about 2500ppm which is the high end of best range. I recall you could not add enough redline to get near that. ZDDPlus is pricey, but you only need a "half shot" to bump a five quart change up about 1500 ppm as I recall.
If I did it wrong, maybe the numbers are off. But, I am the original skinflint and I recall doing the calcs and coming to the conclusion the ZDDP gives more for your $$$ in zinc/phos than redline. Also, it's more concentrated so you "displace" less oil to get it in the mix.
I think redline is OK stuff, but I think the ZDDPlus can get a higher concentration going. To be sure, many engines don't need a 1500 - 2000ppm bump but the high lift cams might. Redline is probably good for the majority of cases.
regards, apologies if my math is off.
- bountyhunter
It's probably the one oil (along with amsoil synthetic) that I have never heard a bad word about.Ok, I'll stick with Rotella-T. Thanks.
The only fear is they can change the formula without warning or notice.
- polkat
- Thank you received: 1
All of this is normal, and if your compression, plug readings, etc are correct, and you don't feel any grit in the oil or see junk in the filter, you've probably got nothing to worry about. I used to build pro-stock Mopar engines. We built them somewhat loose. Fantastic power, but the oil would blacken in 2 runs. Normal.
- toad
- Thank you received: 7
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- Motor Head
- Thank you received: 393
- Bluemeanie
- Thank you received: 15
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
