Swapping out stock exhaust?
28 Nov 2009 16:35 #336336 by polkat
Swapping out stock exhaust? was created by polkat
This has probably been asked a dozen times, but I'm fairly new to Kawa's. My 1982 KZ750 has the stock 'long trumbone' mufflers on either side, and I would like to swap out to something smaller that won't adversly effect performance or cost a small fortune. Can I cut down the existing mufflers? Swap to others? What have folks here done? Images? Thanks!
  • TeK9iNe
  • What did you do!?!
28 Nov 2009 17:07 #336340 by TeK9iNe
Replied by TeK9iNe on topic Swapping out stock exhaust?
Basically, anything you do to the existing mufflers will effect performance in one way or another.
Cutting them shorter/off will deffinately make them loud, and make a noticable drop in midrange power. Doing so may also require (likely) re-jetting your carburetors.
Swapping to another muffler could work fine, but again, there will be differences in the power delivery.
The stock mufflers are well tuned for the bike.
Without spending the dough for a decent exhaust like a 4-1 V&H, or Kerker, you will likely drop the performance.
Or just pull out the baffles, re-jet, and it will be super loud and have a tall narrow power-band. Better suited for track or dragging. Whatever...:laugh:
Cheers and good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
28 Nov 2009 17:38 #336344 by KYKZ1100
Replied by KYKZ1100 on topic Swapping out stock exhaust?
I replaced the stock mufflers on my KZ1100 with a set of 19" turnouts from JC Whitney. I think they were $47 each. They don't have much in the way of baffles so I inserted some 6" baffles wrapped with fiberglass muffler packing. I went up one size in the main jets (120 to 125) and also the pilot jets. I can't tell a difference in the power - it pulls strong all the way through the power band. They sound pretty good, not too loud.
1981 KZ1100A1 Shaft
2007 BMW R1200R
28 Nov 2009 19:03 - 28 Nov 2009 19:46 #336377 by polkat
Replied by polkat on topic Swapping out stock exhaust?
KYKZ1100, yea, I like those. I'm not looking for loudness, just something a little smaller looking. And while I like a broad power range, I'm much more of a cruzer then a racer. can you mention a bit more about how you did the baffling?
Last edit: 28 Nov 2009 19:46 by polkat.
29 Nov 2009 04:48 #336420 by Patton
Replied by Patton on topic Swapping out stock exhaust?
If not already done, might consider selling the stock exhaust system to finance purchase of a new aftermarket system.
Stock exhaust systems in good condition often do well on ebay.
Good Luck! :)
29 Nov 2009 15:20 #336558 by KYKZ1100
I looked up the baffles I used and I guess they were 4", not 6." I got them at JCW also along with some "fiberglass muffler repack material." I just wrapped the baffles with a layer or two of the repack material and then wrapped it with wire to keep the fiberglass in place, then slid it into the muffler. The muffler has three scoops sticking out about an inch into the internal diameter. The first scoop holds the baffle in place.
1981 KZ1100A1 Shaft
2007 BMW R1200R
29 Nov 2009 16:33 #336590 by keith1
Replied by keith1 on topic Swapping out stock exhaust?
nice looking ride....i had one years ago, wish i still had it...then again i wish i had most of the past rides:laugh:
